Ellisstrong
Is the texture grippy?Super easy! Took about 30 mins. Use the new pedals as templates to mark the holes after I put some painters tape on the pedals. Drill pilot hole, finish with 3/16 bit. Gas pedal secures with 4 self tapping screws. Brake pedal secures with 3 nuts and bolts. holes were positioned on the brake pedal where you could drill the holes on flat metal. Bottom middle bolt make sure to align dead center so you can get a wrench on the nut, there is a little open channel on the bottom that you need to align to secure.
