Fob Locked Inside
Jgwram
My recently purchased 2022 Big Horn allows me to lock the key fob inside. My friends's 2021 will not allow the fob to be locked inside. That is what I want. How do I program the vehicle to NOT allow the key to be accidently locked inside?
Derlant1983
Dearborn
Does your truck lock by pushing the button on the door handle and unlock by grabbing the door handle. Without that key sensing system i don’t think the truck can tell where the key is.
Nsleone
Florida
I could be wrong but I think all the trucks have that functionality. If it’s not working on your truck I’d take it to the dealer to have it looked at.
My 2020 big horn has that functionality and it does not have keyless entry so that shouldn’t matter.
If you manually push the lock down, I don't think it matters, like it a pet or child is inside the cab. It should prevent you from using the switches to lock doors though.
Jimmy07
Honorary Site Supporter
Is yours a 5th gen 1500, or a 4th gen classic?
All 5th gen 1500’s (unless it’s a tradesman with manual door locks) will not allow the fob to be locked in the truck. If the fob is inside the truck, and you lock the doors with the door lock switch, they will lock, but as soon as you close the door the horn will honk three times and the doors will automatically unlock.
If you push down the door lock knobs manually on all the doors, then the fob will be locked in.
If you try to lock the fob in the truck by using the door lock switch three times in a row, the doors will stay locked on the third attempt.
Mountain Whiskey
Yea, my 21 won't let the door lock with the fob inside. I assume the sensor in the seat needs pressure on it so it knows you are in the truck.
Mountain Whiskey
No, there are 4 antennas. Two that sense when the fob is inside the truck, and two that sense when it is outside the truck.
Then how does it let the door lock when you are in the truck with the fob but not when the fob is in the truck and you are not?
Jimmy07
Get in the truck and close the door.
Remain in the seat with the fob inside the truck.
Open the driver door.
Remain in the driver seat.
Press the lock button on the master door switch.
Shut the driver door.
Report back the behavior you experience.
6of36
Michigan
Are you just opening the door, tossing in the key, and locking, or are you driving, getting out , but leaving the fob inside, and locking? It makes a difference.
vincentw56
Not true. My 2020 wouldn't let me lock it with the key in even before I installed the passive entry.
fast ed
if you leave the key fob in the vehicle, you can lock doors with second key fob. My 22 longhorn works like that.
Trippi
Macedon NY
how is that possible? I have at times unknowingly had 2 fobs in the vehicle. Get out and lock - truck will beep and not lock because there is still a fob in the truck. Jeep Cherokee does the same thing.
Jimmy07
One fob inside the vehicle, and one outside the vehicle. As long as the antennas sense a valid fob outside the cabin, it’ll allow the doors to remain locked.
FLiPMaRC
NJ
Yes it has happened to me. I left my fob in my jacket in the backseat. My wife had hers on her. The truck allowed me to lock the doors via the lock button on the door handle. I didn't notice until the next morning.
fast ed
like I originally said as long as there is a key fob outside you can still lock with the first fob inside
