BowersFJ
- Oct 8, 2020
What you have front 5100s set to?
It’s in his sig …. #4 …. So theoretically 3.3” of lift in front
A couple of questions..
If CV angle is an issue is there a diff spacer that you can use to reduce that angle without going to a full lift?
Has anyone ran 37's with either RL 3.5" w/ORG or with RL 3.5" w/5100(ORG) and 5160? Specifically 37x11.5 on stock rims? I love the look of the stock rims but could switch out if needed for space.
I would really like to run 37's just to be a little different and fun. I don't drive a whole lot, typically it's less than 800 miles a month so I really want to enjoy the time driving a little more.
But will they fit?37’s will look stuffed with anything less than a 6” lift
But will they fit?
I had actually found this before : https://www.customwheeloffset.com/w...00-fuel-contra-readylift-suspension-lift-35inGo to Custom Offsets website, go to the gallery, plug in your specs, and they will tell you, and show you pics of trucks with that setup
Guys if I have a stock set up 2021 bighorn and get new wheels with a -12 offset and leave everything else the same is this had for the truck or is new suspension required? It fits without any issues and has no rubbing or anything
#4What you have front 5100s set to?
with a lot of cuttingBut will they fit?
Did your truck come with the off-road package? I keep seeing #4 and #5 setting. Trying to decide which one to use. I have a 19 ram longhorn without the off-road package and want to use the bilsteins and RL 3.5 sst kit.
Mine does not have the off road package.Did your truck come with the off-road package? I keep seeing #4 and #5 setting. Trying to decide which one to use. I have a 19 ram longhorn without the off-road package and want to use the bilsteins and RL 3.5 sst kit.
No, standard Big HornDid your truck come with the off-road package? I keep seeing #4 and #5 setting. Trying to decide which one to use. I have a 19 ram longhorn without the off-road package and want to use the bilsteins and RL 3.5 sst kit.
