Biga
You can turn it off in the gen 5's. Just 2 little toggle buttons in my truck, one for front, one for rear, and they stay off when the ignition is turned back off/on again. It's a non issue if you're worried about that.
I also understand it's possible to just have the warning sound and dash notification, without the truck actually braking? I could be wrong about this part, I haven't played with my settings enough. But the 2 toggle switches definitely work as described above.
yes, I'm pretty sure you can just get a warning sound and flashing light. I would probably just use that if I had it, my sister has just a warning on her Chevy and it works well.
