1. Why remove or adjust RamBoxes? Maybe the doors don't close or sit right? Maybe you need to get into this area to install modify the bed, wheel well or insert, or you are installing another custom RamBox mod? Doesn't matter. Here's an easy walkthrough.
My passenger RamBox just didn't close enough to suit me. Kind of looked like it was already open when walking up from the side. Looked all over for ways to adjust and decided it had to come out. Here's the tour:
1. From underneath near the bumper, you'll find an access hole on each side. Unclip the right, larger connector shown [EDIT the left connector is the bed light and does not need to be disconnected] (slide red tab out with screwdriver maybe 3mm and then you can access the part to push in and it will disconnect). Driver's side is a double connector as it has the AC wiring for the outlet as well. This photo is passenger side with bumper to your left. The fiber cover seen at the bottom has the air compressor above it.
2. Remove all bolts inside the RamBox including the two black ones on the latch pin (where you see two welded on nuts - but leave those alone) and two each on the outside hinges that go into the bed. All of these 8mm bolts are identical and appear to have red locktite on them.
3. With RamBox lid open and from standing inside the bed, pull up on the whole assembly by grasping the two sides of the lid. It pulls straight out. You can then set it in the bed but it will want to tip over if the lid is open. You can close the lid (you can open it via the physical key since it doesn't have power) or you can lay it on it's back in the bed and carefully let the lid open. The black top of the lid will be against your bed and not the lid paint.
Here are shots of the bed without the RamBox installed. These are all passenger side and this is looking toward the rear. No idea what the scalloped "patch" is on the left outer wall. Very hard and feels glued on.
Looking down at rear. The square hole is where you disconnected the wiring from below.
Looking to the front. I know some had asked about stake pockets on a RamBox. You can obviously see they are not there but you can also obviously see there is plenty of room for them should you be a better welder than I am.
And front looking down.
Here's the RamBox removed, back end.
From back.
Least exciting, the front.
And the outside where the lock is. The lock can be adjusted, just not without removing the RamBox. Not sure who designed this but by removing it, you can now access these two black bolts and there is a fair amount of free play in it. This box was adjusted all the way up leading to the "looks open" I was dealing with. I tried lowering it a few times but no dice. That led to other fun and games. See the shiny silver washer on the bottom left?
Well there were two of them silicone glued to the bottom as shims.
After replacing the RamBox in the bed, I was pushing down on the bottom and the left bolt hole with shim still had a little travel to hit the bed. The right one was bottomed out so I pried the washer off and what do you know, it fits far better now. I also wound up moving the adjustable latch part all the way to the bottom of travel.
After all was reinstalled, it's a tad too tight now. You really have to slam it but it looks perfect. I'm going to leave it a week or so to see if the weatherstripping gets persuaded, otherwise I'll just pop it out and readjust again.
From back.
