Judead
- Jun 21, 2021
Edwards,No, because they are still not perfect. The adjustment just makes them less crooked. My passenger side wasn't crooked originally, just too high on both sides. After adjustment is was virtually perfect but now after a Texas summer the top black plastic is bowing upwards on the ends and I've got no fix for that yet.
I did respond to @RamCares when they wanted extra info on the truck for this particular issue to report back which tells me that someone at Ram is at least collecting data on the issue.
My driver's side is still high on the rear but since I've got the original latch that requires full removal for adjustment I ran out of giveadamn before I got it perfect. I'll lean on the engineering excuse that it's due to the latch not being centered on the lid...
hey I just registered because I was reading this thread. I have a 2021 ram 3500 Laramie I just took delivery on. The ram boxes are not aligned properly so I plan to tackle this I have an ulterior motive as well. I decided to keep the passenger ram box clean to be used as a cooler. I tested it yesterday on vacation in Florida. It wasn’t real hot in fact mostly overcast maybe 90’s at one point. 5 bags of ice and at 8-9 am they were dumped in. All ice was gone by 5pm. I am a little disappointed on seeing the really good write up you did as there looks to be no way to insulate these. Obviously you can’t the bottom because they rest on the bed. Probably acts as a thermal conductor from the bed as well. Wonder if it is possible to build a form and spray foam around the rambox as well as get some under that support to help keep ice a little longer? It’s been a while since you did this but was wondering if you would remember. I have access to a CNC router so wanted to know if this was possible. May follow in your footsteps to figure this out. I also think my tops are slightly warped and they are brand new. Even with all this slight problems I would rather have them than not. I might look at the tops and see if I can make a way to straighten them with stainless. I am sure you have to be careful due to the lid becoming too heavy for it to stay up or slamming your hands while in the box.
