Fabtech Lift Not Aligning Properly
Astro- did you ever get this sorted? I’m about to pull the trigger on the Fantech 3” Resi coilover lift but read about the bouncy rear end and alignment issues is making me rethink things.
Any updates with this? I’m also thinking about buying this or the readylift kit.
Op hasn’t logged on to the forum in almost a year. Probably best to start a new thread
I replaced my rear shocks which helped the bounce a little bit but not completely and now noticing tires are starting wear a bit uneven. Might be a defect with the kits. @fabtech
The bounce in the rear is absolutely untenable with these rear 2.25 Dirtlogic shocks, I just installed their 3" Lift kit ( coilover ) on my 21 Rebel, and the bouncing is just ridiculous. I cant in good conscience sell this kit.
I have a 6” inch Fabtech lift kit with rear 2.25 Dirtlogic shocks and the bounce was pretty bad. I think they are pretty crappy shocks tbh. Switched over to rear Fox 2.0 and issue pretty much corrected itself. I also added the Helwig sway bar with 4x4 core end links and it rides and handles great now.
