Nickv1214
- Nov 14, 2019
Handle was brokenWhy did you need 2 do this?
Oh okay it looks like in the pictures that the door was scrapped up but maybe not.Handle was broken
Appreciate that .Thanks for the write up! It's posts like these that always bring me back to forums like this.
No it does not need to be removedSo the interior panel did not need to be removed?
Interior panel only needs to be removed on driver side with keyholeSo the interior panel did not need to be removed?
Thats what I was told by the dealership when they chipped my door handle, but you know how they are...could be wrong.Really I’m actually in the process of removing them all to vinyl wrap the truck . I’m almost on to the driver side I didn’t no that . Why exactly do you need to remove the door panel ?
Yeah definitely wrong . I just provided the picture up top , definitely don’t have to remove any door panels to remove the door handlesThats what I was told by the dealership when they chipped my door handle, but you know how they are...could be wrong.
Ok guys got this all figured out . Inside the door is a access hole which will get you to the only bolt that needs to be backed out . It’s a t25 torx , and you do not need a long torx screw driver . A standard 4-6” reaches
No prob, glad this helped you . I searched high and low for a couple months before I finally just had some time to dive in and figure it out . Super easy process though ,nice jobfirst off I want to say thank you I looked everywhere for a video on how to do this and couldn’t find it but just followed your instructions worked perfect less then a hour and it was in the dark the back ones I just replaced the cover so I didn’t have to remove the door seal which was actually harder then taking the whole thing off
