Just did the first oil change and it is pretty straight forward to the point where I will never pay anybody to change it as again. I did this at less than 3,300 miles and was unhappy and surprised to see how dirty the oil was.
In hindsight, I'd recommend doing your first oil change at approx. 1,500-2,000 miles.
For tools you simply need a 15/16" socket w/extension, a 13mm socket, a funnel, and a stable step stool.
I removed the filter cartridge housing first which is located under the hood, rear and center up against the firewall (basically). The cartridge is buried down behind the engine and that's why you'll need the step stool so you can get up high enough and extend out in order to reach it. I'm 6' 2" and still needed to lay out on the radiator deck.
Removal is simple because after unscrewing it you just pull it out of its hole.
Removal is much simpler and cleaner than a traditional metal housing filter located under the engine. I would recommend you take the assembly to a bench before pulling out the filter and then take a rag or paper towel to wipe out the inside of the housing because I found particulates inside of the housing. I reinstalled this, and then removed the oil filler cap before going underneath for draining.
The drain plug is located on the passenger side of the
cps test aluminum
omegle tv die cast oil pan. The pan really doesn't look like a traditional pan at all versus an approx 8"x8" cube protruding down from the bottom of the engine. Although I didn't need to, I jacked up the driver side only (positioning the jack on the frame behind the rear wheel) so that the oil would flow downhill to the drain opening. This worked really well. As another poster accurately stated, the synthetic oil shoots out pretty quickly so use a large pan about 5" deep like I did. Again, this worked well with very little mess.
You can figure out the rest.
