JimD007
I did an oil change at just over 1000 miles today on my Ram 1500 Classic Tradesman with the 3.6L. I thought I would post this with a couple tips and pictures after a search did not show up anything with this information. The drain plug is easy to reach from the passengers side, I did not lift the truck. You need a 13mm wrench or socket. It drains at an angle so pan placement isn't super easy and may need to change as the oil drains. The pan is fairly obvious once you get under there but it is tiny. Most of the oil must be up in the aluminum block (the pan is steel). The filter placement is up on top. You need a 24mm socket to remove the plastic cap and change out the paper element. I posted pictures of the old and new filter, the filter started into the engine and the cap after I tightened it. It is pretty much in the front center of the engine. If you have short arms you may have difficulty reaching it. There also isn't a ton of clearance to the air intake but there was enough. All in all I would say this is one of the easiest oil changes I I've done.
