Digital Key setup 2025 Laramie
when I pulled in my driveway tonight truck said an update was available with ‘new features’. We’ll see what it is when I go out in the morning
It was probably the security gateway module update, which will allow for the rest of the necessary OTA updates.
Yep, I just checked my truck and that’s what it was…
While this didn’t solve our problem, it could have been just the first step…
It looks like the app for the phones themselves need to be updated, in order to enable this capability…
I have no idea if I got an update or not. Version FCA-MY24.U35.26-PROD
I have the same version. I noticed an update available this morning on my screen, but did not update :(.
There is still so much confusion with the NFC and Digital Key and it still not working and maybe woking for others. My app has expired and I did not renew any options and apparently, and maybe someone can verify this, but without the app you will not be able to program the NFC card or the digital key ? The app, to unlock, lock, remote start is not something I use and didn't want to spend the extra money for this. Unfortunately, the NFC and digital key should have been something that should have been made available when we purchased the car and had the app to do so, but we all know how that went. So, I'm assuming, no app, no NFC or Digital and there is a good possibility that even if you have the app, the NFC and digital key still won't be available? And like most on this forum for this issue, you can not get a straight answer from customer support/MOPAR.
Appreciate the very informative and helpful updates from folks. Looks like progress is being made, and folks sharing their experiences helps the rest of us still waiting for the updates. Thanks all!
I'd recommend you take some time and read through this thread. There's a lot of good information here, and it might help you better understand the situation. The backup NFC card comes with all appropriate models, normally in the center console when delivered, and they work immediately. They are already uniquely programmed to the truck.
The Smart Phone As A Key (SMAAK) feature does not yet work, but it is being rolled out now. This will allow use of a phone or watch in a manner similar to the key FOB. The backup NFC card is something to carry in your wallet in case you forget your phone or FOB, or something happens to them. As noted in the posts above, people are starting to see Over-the-Air (OTA) firmware and software updates now.
The ability to remotely start using the Mopar app is totally and completely separate. This is a subscription based service. The remote starting is part of a plan that offers a free three month trial, and you must pay after that (if you do pay, you get another three months free).
The NFC card does not and has never worked since day one. I have been told that in order to get the digital key (SMAAK) to work, when it's rolled out, you need to open the app and it will have the digital key code. So, if that is the case, getting the digital key to work is contingent upon having the app. Right now, the app only tells you the fuel level and vehicle health, recalls and digital glovebox. The instructions on how to get the digital key programed, when it's available, tells you to open the app and get the digital key code.
So, If what I'm told is true it, sounds like I'll have to renew the app, just to get the digital key code and not knowing how long it's going to take to get the code in the app, spending $14/15 a month for the app that gives me features I really don't use, is a waste of money. Getting the NFC to work might be something useful because there are about 5 locations when I'm parked there that is causing some type of interference and I can only lock the door from the inside when i get out, the fob and/or handle will not lock the truck. When i return to the truck, the only way to unlock it is to use the manual key inside the fob and then when you open the door the alarm goes off. It may be RF signal from somewhere that causes this issue. Until I get back to the dealer for this and other issues, it's something I can live with. It would interesting to see if the NFC card would help when this happens, but getting the NFC to work is on the dealers list of things.
I recived the update also, same as others - this was just the Security Gateway Module update. Uconnect version didn't change (FCA-MY24.U35.26-PROD)
My truck is hooked to my wifi at my job and house. Does it just "magically" get the update or is there something I can do to force the update? I an on FCA-MY24.U35.26-PROD
Well gents I am sad to say I just spoke with Ram and the latest update "we hope it will be released by the end of the year". Honestly I'm annoyed because I upgraded to the Laramie level 2 because this would be really convenient for me. The option shows on my radio under settings and then doors and locks. Scroll to the bottom and it gives instructions how to pair but the tile is still missing in my app. Maybe they'll get it together and provide what we're paying for!
This is interesting because if you go to the Apple App Store for the RAM App and read the reviews (sorted by most recent), for the wave of negative feedback regarding the Digital Key the developer response is “coming very soon”.
Is there a dealer on this thread that might be able to second check? The last I saw here was that we were supposed to start seeing FOTA updates… If “by end of year” is true, that would be a significant reversal on behalf of RAM.
My question is..... how hard can it be. Other manufacturers have done it. WHat's the problem?
^^^ THIS ^^^
Just some transparency on these issues would go a long way. Without it, we tend to go more negative than we may have to. I agree, there really can't be much excuse for this delay. The back-up NFC card works. Another member of this thread has his working as advertised. So.... what gives??
  • Jako
