Side Step Selection
On the topic of side steps, I guess I should mention that I typically don’t like them but they are a necessary evil (at least from an off-roading perspective) as most designs detract from the vehicles' clearance and may even decrease the break-over angle. But they are a necessity for my daily driver/weekend warrior vehicle; at 6’ 3”, I personally have no issues getting into or out of my lifted Rebel, but my wife is a lot shorter at only 5’-3” and I also have other shorter/older occupants I need to consider.
Originally, I had planned on going with the AMP Research power retractable side steps. I have installed them on at least 4 other builds and the systems always performed flawlessly for me in all weather conditions (admittedly, I don’t live in an area that gets ice storms where I am sure the motor linkage assemblies might freeze up). But for occasional water crossings and desert/dune runs, the motors are sealed pretty well and so never any performance issues. In addition, since the AMP steps retract high up under the vehicle, I have never had any clearance issues for the type of trails I typically run.
However, as is typical of me when I am ready to order something, I started second guessing myself. While I don’t mind paying top dollar for top quality gear, the AMP asking price of ~$1500-$1900 per set (depending on the model) is high enough to give some pause as I could invest in some real rock sliders at that price.
While some have done a great job of fabricating their own and/or going to a local shop, I don’t have the patience, talent, and time so decided to look into some quality rock slider fabricators online. Not too many options out there (yet) but these looked very good and I almost called them:
https://white-knuckleoffroad.com/ram-1500/
https://www.mapleoffroad.com/new-products/dodge-3rd-amp-4th-gen-rock-sliders-with-rub-rail
photo courtesy of White Knuckle Off-road
But as I thought about it, I had to remind myself that I am not planning on taking my daily driver on highly advanced trails with large, car-sized boulders that I want to climb over. Moderate trailing is all I really want to do with this rig (if not, I will build a Jeep). Also, while newer rock slider designs can now be outfitted with a steel mesh or diamond plate step, the slider height (on the lifted truck) really doesn’t help my vertically challenged passengers. So I nixed that tempting idea.
Next was the “soft” slider/running board options offered by Go Rhino (Dominator Series), n-Fab (various), Westin (Outlaw Series), and others. I say “soft” slider as these are really just nerf bars/running boards with an extra rub rail/tube underneath. While that may provide some minor protection, the systems attach to the body, not the frame, so will not support any vehicle weight at all. But I thought the designs were more interesting and fitting the style of an off-road vehicle more so than the typical flat, wide running boards also offered by the same manufacturers. The argument for selecting a flat, wide running board however is that you get a continuous platform to stand on along the entire length of the cab and you may even get a measure of ding protection from those obnoxious parking lot patrons.
Anyway, my preference was the n-Fab selections mostly due to the fact that I have used several of their products in the past and was always pleased with the quality and n-Fab’s service. In full disclosure, n-Fab still uses a couple of my photos from previous builds to advertise their products (and so now does Walmart, CARiD, and others…lol) but I am not a paid endorser.
Also, n-Fab recently came back on my radar as a friend of mine, who also purchased his Rebel around the same as mine, had just installed a set of their powder-coated RKR Nerf Step System which includes an under rub tube and detachable side steps.
I really like his setup but the drop steps are really quite narrow and I thought might be problematic for some as they are hard to find when exiting the vehicle (or when I get older and can’t see so well).
So instead, I thought I would go with the beefier looking Podium LG & SS side steps as they are constructed with a 3-inch stainless steel tube with integrated steps that are much larger (and therefore safer and more functional). The main tube also sits high and tight to the vehicle body for a clean modern style.
Eventually I decided that the 3-inch round tubes with larger drop steps would just detract from the additional ground clearance (and increased break-over angle) I achieved with my recent 3-inch lift on the Rebel. I nixed that idea as well.
So I am back to the AMP retractable steps as they drop well below the rocker panel to provide a low, wide, safe step up for others while retracting fully up under the rocker panels to retain my ground clearance when four wheeling. In addition, you can have the side steps in the extended position for a platform along the entire body side (vs. a small step) for when cleaning the vehicle and/or accessing the roof. I have taken these steps off-roading on many a desert and mountain trail with my moderately lifted (3-4 inch) vehicles in the past with never an issue (again, avoiding highly technical trails).
I upgraded this time to their Powerstep XL version which is specifically designed for lifted trucks as the running boards drop an additional 3-inches than their standard version but retract into an integrated “rocker rail” for a seamless look. The system is made of aluminum so lighter than more of the other nerf/running board options and comes with an ORB “plug and play” connection.
I ordered the steps through Amazon and should have them by this weekend. The best thing is I caught the last pair they sold under a special offering that was almost $600 under the list price, so really a win!
edit: grammatical corrections
