There is a defective part behind the steering wheel near the clock spring that cause rattle and grinding noise. Please someone have the name or number of the part. I needed to help the technician to fix my truck. It’s an error by the manufacture in the construction of that part.
Why would you need to help the tech? He has DealerConnect and can look up the part himself - it even has photos AND and Recall/TSB/ or STAR case regarding your issue ..
Shared with Dropbox
www.dropbox.com
Hi, if you do not have this problem don’t worry.
We are trying to assist you .. let's help him learn as well ..
We have no information regarding your vehicle as your signature is empty. Maybe you have a 4th gen and we are all lost to your request? We can only guess that you are referring to a DT (2019 New) ..
There was a known issue regarding the Intermediate shaft (which isn't next to the clockspring) which was "grinding"
There is a DAMPER (part
68306867AC ) But I haven't seen one of those being replaced (yet)
Is the upper or lower plastic portions (shroud) of the column rubbing and you feel like it is a grinding noise?
www.socalmopardirect.com
