Creaking noise
Hi All,
I found my creaking steering wheel issue today. I have a 2021 Ram 1500 Rebel with 2000 miles on it. The creaking noise would happen more often when I'm turning the steering wheel in a slow turn. It sounded like the noise was coming from the clock spring right behind the air bag but that was a red herring. The noise was actually coming from the aluminum coupler at the base of the steering shaft inside the cab. The noise would telescope up the steering shaft and the steering wheel acted like a speaker. There are 2 cheap rivets holding it together. You can feel the slop and feel the creaking noise very easily when turning the steering wheel while you have your hand on the coupler. I sprayed some lubricate at the top of the coupler. It took a few minutes to work in the lubricant but eventually the noise went away. If the noise does come back I will drill out one rivet at a time and install a bolt with a locking nut and tighten it down good. I have included pictures. Please let me know if this help anyone out.
Lloyd
I used this info and traced mine to this same issue, is the lubricant still fixing the issue? What lubricant did you use?
I’m having the same creaking noise. If there’s a service bulletin out there, pleaee post it as my dealer was unable to replicate the problem.
Hi All,
Lloyd
Thank you for posting this. I was about to lose my mind after troubleshooting this the last few weeks to no avail on my 2021 Laramie. I put some lubricant right where you suggested last night, and it is silent today.
My 2019 has had a creaking noise off and on for the past few months. It noise appears to be coming from the front suspension. When I first noticed the noise is was during wet or humid weather, now the creaking noise is happening more often. I purchased a lifetime warranty when I bought my truck, when I took my truck to have the noise checked the dealership wanted to charge a diagnostic fee.
We have a 2020 Ram Limited and have been dealing with this issue for 2 years. Our dealership has been very helpful and replaced nearly every part, but the creak is still creaking. It does go away after they take everything apart and I’m assuming it is because it is all tightened up when they put it back together. The creak happens with any steering wheel movement, but mostly right at the beginning of a movement left or right and also on bumps or rough roads. It’s starting to drive us all bonkers.
Hi there,
We are sorry to hear about this ongoing vehicle concern. We'd appreciate the opportunity to assist. Do you plan to revisit the dealer, as this issue is still occuring? Please send us a private message with some additional details.
Lex
Ram Cares
Throw mine out there too…starting creaking about a month ago. The video posted here sounds more like knocking where mine is a true creak when you turn (sounds like an old door being opened). Driving me insane! Sounds like a truck that I’ve had since 1987 but this is a 2020 🤣. Is this what everyone on here is referring to??
Has anyone had any luck resolving this? I have 2020 big horn with the creak like an old door like someone described it. I'm thinking it's rear sway bar bushings? Idk if that's a possibility or not.
Went to the dealer twice for the creak while turning, they were no help. Literally put a sock in it and haven’t dealt with any creaking since. No more headaches from the dealer this way. I posted detailed pics where to place the isolating material (sock lol) in another thread.
Hello, I found this link while searching for an answer to my 2021 ram squeeking issue. What and where are talking about putting the sock or rubber to stop this squeal? Thanks!!
Well guys I found my infamous steering wheel creak. I recently had my truck lifted with a rough country 3 inch leveling kit. All new control arms upper and lower with ball joints. All new struts all new cam aligners and wheels and tires. On the day to get my truck aligned the power steering failed due to electrical issue from the recent recall it had done. So that was fixed due to spliced wire. So about a month after being lifted my driver side wheel bearing failed. I bought a new one and installed it. That noise went away and my steering wheel started creaking. Just last year my Ford Focus St snapped a tie rod and totaled it. So hearing this had me freaked out. I been spraying my intermediate shaft with wd 40 and pb blaster and been tearing apart the steering wheel and applying the sock in-between the mass module wiring and still creaking. Well guys it is my hood rubbing on the plastic and I will post pictures. It's insane !!!! It is like that on both sides for some reason if anyone has any ideas of how exactly to fix it, let me know please!
Hi All,
Lloyd
Is this under the dash
