ivan_popko
- Apr 8, 2024
Hi! I'm using comma with sunny for a few months already, so far so good. I'm for a mirror mount now and discord invite
Hello gents, newbie here. Happy holidays! Apologies in advance if any of this is already covered.
Is there a new Discord link? The links in this thread all show expired.
Second - I’ve got the C3 with SunnyPilot release-c3 successfully installed on the device.
I turn the truck on and C3 device starts to go into calibrate mode and then I receive a “CAN Error - Check Connections” warning. I’ve tried cycling through the ignition a few times to clear it, but it doesn’t clear.
I’ve checked the connections and all of the connections are fine.
Any suggestions?
There is a connection error in your wiring. Check the harness. Unplug it and plug everything back in. Hit us up on Discord for quicker help.Hello gents, newbie here. Happy holidays! Apologies in advance if any of this is already covered.
Any suggestions?
Thanks - I will check all of the connections again.
Yeah the problem is is you have a 2024 HD. You need to install FrogPilot or our real fast version but FrogPilot is going to be a better option.This is the 3rd time I’ve checked the connections - all of the connections are complete - and I still receive the error.
The C3x is communicating with the truck because when I unplug the harnesses, it obviously severs the connection.
2024 Ram 2500 Limited with all the adaptive features.
I have no warnings anywhere else.
Do I need to install some special fork?
fork installer generator
frogpilot.download
I’m excited to get this thing operational. Is that the exact URL to type into the C3x when I re-download the software?
Thanks for your help VincentI’m excited to get this thing operational.
It's not working. Have you tried to unplug the cable from the back and try again?I’ve got FrogPilot installed successfully, no connection errors, but I’ve been driving around for 30 minutes in calibration mode, but calibration has not increased above 0%.
Does this step require an internet connection? Or is it simply not working?
It would be much faster and easier to do this over Discord. I assume you turned ACC on first before pressing the set button.I restarted the truck and was able to get the calibration to work - great.
The C3x screen has FrogPilot successfully calibrated and green signals (other than internet connection when I’m driving) down the left side of the screen.
I tried to deploy the FrogPilot using the ACC Set button on the steering wheel and I received Zero automated steering wheel feedback from the system (none, which is worse than the stock Adaptive Lane Centering that at least bumps you back into the lane).
The system then disengaged itself from ACC and sent a “Check Radar” message to the C3x screen. No warning lights or system faults on the dashboard.
The windshield is completely clear (no weather).
I must be missing something - apologies as I am new to the Comma platform. I’ve used Ford OEM driver assistance features previously and love them and was excited to attempt to get this functioning.
Any feedback is welcome!
Could anyone provide me with the discord link? Or how to obtain the mirror mount?
Could someone please provide me with the discord link, it seems the one I have found here no longer works? TIA
You could build the harness, but I'm not sure with the newer versions. Us OGs had to build our own in the beginning.Hey guys first post here! 2024 Ram Rebel 2500 I have a Comma on order but the wiring harness is on backorder? Any Suggestions? Also need an invite to the discord!!
