Comma.ai
Can you explain the process. Do you turn on your cruise control and then turn on the Comma? Which Comma do you have?
There's only one comma that you can get. The comma is running the whole time as a dashcam but isn't activated until you turn on ACC using the button and set a speed. Then it takes over steering while the factory ACC controls the gas and brake.
So is your lane sense button above your radio showing that its on? I didn't know if you had a Comma 3 or a Comma 2.
Sorry I'm so full of questions that seem redundant.
I have a 3. The 2 is obsolete, but still works in a limited capacity. When the Comma is active the light on the button is off. It's weird because when the light is on LKAS is off. You can use the button to disable comma steering while using ACC. But factory LKAS functionality is replaced with the Comma.
How difficult was it to install? Are you happy with it compared to the factory LKAS?
Well, there is a huge difference between the two. LKAS just nudges you back in the lane. The comma is completely hands free. There is a limit to the turning though. So, depending on some curves, you need to help it turn.
Installation is simple. Remove the mirror cover, unplug the DASM connector, plug in the Comma harness, install the software.
Would like an invite to the discord channel. Has there been any progress with the 25's? I am glad that Ram is offering self driving now, but it's more limited than Comma in some ways. I have an order out for a 25 RHO with hands free, but curious to expand its capabilities.
No, there's no progress. The encryption and the fact that you can't just insert something on the canbus, is what's holding it back. It might be several years.
Get 2024
So, when you disable the factory LKAS with the button above you radio, it disables the comma's ability to steer. Correct? This makes me think that I will need the radio with the button then.
I would like an invite to the discord channel please
Only if you want that ability. I've had the Comma for almost 3 years and never used it once.
Anyone know where I can get a harness at? Coma is telling me 3-4 weeks out for a harness.
I appreciate the link, but I get the following message “Safari cannot open the page because the address is invalid”
Invite link is expired, can someone share it again please?
