badpewterz
- Jun 24, 2020
Yes there is a map sensor also but unless ram runs in speed density which they do not it also uses in this case "air charge " sensor to get technical. Now it doesn't happen often but I have seen where to much oil from a oiled air filter has contaminated the sensor and set a light. In this scenario it would not be covered but warranty would still be valid if that makes sense to you?The MAP handles that plus input of fuel,etc, etc...it's just not a MAF. Aftermarket could let in some serious containments that could eventually lead to engine failure. Probably would take a long time...but can still happen easier than if you had a stock...ish filter in.
And again I never mentioned engine failure. That would take alot of time and neglect with the light in and running like crap and just ignoring it. Even then the computer would shut down before it got that far
I have alot of background in the performance industry and had my personal 2000 camaro with a 416ci ls3 that we ran in speed density for the track and ran off the maf for the street.
Now back to the map sensor if/when that gets to much oil in it. It should be on ram as we know the blow by issue already . That they would not be a le to blame a CAI
