I think I’m seeing tonneau covers in my sleep at this point...
Been researching for days and (for better or worse) I’m looking at tri-folds.
We live at 7800 ft in northern NM. A lot of roads here are gravel/dirt and there’s an omnipresent layer of dirt/grit on everything (detail your vehicle, leave it in a closed garage and it’s still covered in a layer of ‘nature’ in 24 hours). This makes me leery of the aluminum top panel models. Everything here takes a real solar beating. We’re typically dry weather-wise, but monsoons can drop heavy and we get our share of hail (ranging from pea to dime size typically). All of that makes me think the FRP top panel type would be most durable. That leads me to the BAK F1. Like the look of the Lomax, but not thrilled with the fact that, in full flip-up, it doesn’t contact the cab (seems an unstable position to me) and it has the aluminum top panels.
Can’t do anything until I actually get my truck (it’s currnetly stuck in the freight yard in Peoria, AZ) and see where the BUG rails are mounted, but want to be ready to pull the trigger in the tonneau 5 seconds after I take delivery.
Have the 5’7” bed on limited 4x4 crew cab. Don’t want a one piece or a retractable (typical use will be Costco runs, so trifold is ideal for function). Not overly concerned with 100% water-tight, but definitely concerned with long term endurance in our sun, wind & dirt.
Anyone have another brand to pitch? (Thanks in advance!)
