- Jun 8, 2021
- Solutions
- 1
I’ll take your word for it but I’m not gonna test that theory out anytime soon. Couple minutes over 100 mph will just draw WAY too much attention from Johnny LawYour tires wouldn't blow unless you are driving at sustained speeds above the speed rating of the tire. Meaning, more than just a couple minutes, or a short blast to see how fast you can go
Many years ago I had a 66’ Delta 88 with a big block in it. Anything over 80 mph was scary and it felt like I was driving a small ship in the rough seas. Steering correction was crazy. Pure definition of a boat if I ever saw one.These 6500lb trucks just aren't built to break any land speed records that's why they are governed. They aren't corvettes
It's got nothing to do with tires.Assuming you were correct, how would you explain the 118 limit on the TRX? That’s what the tires are rated for.
This is correct.Your tires wouldn't blow unless you are driving at sustained speeds above the speed rating of the tire. Meaning, more than just a couple minutes, or a short blast to see how fast you can go
Unlikely. If you haven’t seen the driveshaft on a TRX, it’s YUGE.Image this headline
"Supercharged TRX driver dies second week of ownership on the racetrack going 120mph because a the driveshaft snapped in a completely unmodified truck."
I live in MA. I don't think anyone in this entire state owns a TRX.Unlikely. If you haven’t seen the driveshaft on a TRX, it’s YUGE.
Driveshafts can't be rated by MPH. That's just not how it works.I live in MA. I don't think anyone in this entire state owns a TRX.
Point being is parts break, the faster you go the more likely something will break and cause lots of damage or loss of life.
I recall reading somewhere that the driveshafts on the 1500s are only good\safe until either 125 or 135, I forget which it was.
From the nerd side of things, this is a good calculator. They're using SAE values for the coefficient of friction. It checks out, and is giving accurate (but limited) numbers.![]()
Stopping Distance Calculator
Stopping distance calculator finds the distance your car travels before it comes to a stop.www.omnicalculator.com
Having driven multiple cars as fast as I could on the Mid-Ohio race track, I know the feeling. Some cars "float" while others feel planted. The best street legal car I've felt at speed was a 2012 Charger, and it was subsequently the fastest I've gone in a street legal car. No doubt there's better cars, that's just the best one I've driven there.Many years ago I had a 66’ Delta 88 with a big block in it. Anything over 80 mph was scary and it felt like I was driving a small ship in the rough seas. Steering correction was crazy. Pure definition of a boat if I ever saw one.
I was amazed how stable my RAM felt at 120 mph for something that big and heavy. Crazy how far vehicle suspensions, steering and aerodynamics have come even on large trucks. Probably a good thing they limit them. Eliminates lack of common sense from the equation.![]()
I'd say this is your answer right there. They've probably only tested, or calculated various parts and/or aerodynamics to given speeds, and those likely don't go much beyond where the limit is set.It's got nothing to do with tires..... ....Manufactures don't want people to drive too fast and die because a part of their car\truck broke at speed.....
I'm pretty sure the drive shaft example was just an example. You may have taken it too literal.Driveshafts can't be rated by MPH. That's just not how it works.
He mentioned specific MPH for what he thought was the limiting factor for the driveshaft. There is no other way to interpret thatI'm pretty sure the drive shaft example was just an example. You may have taken it too literal.
I don't think Darksteel165 was saying it would specifically be the drive shaft to fail, or to be the part setting the limited speed. Pick any random part for the example. A lug nut, a tire, a valve, a gear in the transmission, anything. I think the point was that they don't want a part to fail and cause them to get sued so they limit at what they think the weakest link is. The driveshaft was probably just an item that came to mind but really it could be anything (even the tires as someone already mentioned).
I read somewhere that claimed as a particular speed\rpms there would be an amount of vibrations that could cause it to break. I don't have the thread on here saved.He mentioned specific MPH for what he thought was the limiting factor for the driveshaft. There is no other way to interpret that
You obviously don't hang out with the same group of car guys as I do. I get left behind with the factory speed limiter on most cruisesanyway, 106mph and 118mph is.more then enough for the capability of our trucks on the street (safe wise), dont see why we would need to go faster. for those who race on tracks there is always the possibility of a programmer to delet that
105 on highway is reckless driving. Stopping distance calculates to over 900 feet. Anything goes wrong the charge should be attempted premediated murder. Slow down. The life y'all save just might be mine.These 6500lb trucks just aren't built to break any land speed records that's why they are governed. They aren't corvettes
lol no i dont, but if i would, i probably get a car ment for that (even then i would not go that fast on streets nor hwy) what are they driving?You obviously don't hang out with the same group of car guys as I do. I get left behind with the factory speed limiter on most cruises
I found 24 members from the trx forum that registered their trx'sI live in MA. I don't think anyone in this entire state owns a TRX.
They like to roll race on the interstate. Most run radar detectors. I don't partake in the racing myself, but if you dont want to get left behind, you have to drive fast. Speeds over 120mph are common. Mostly Mustangs, Camaros, and Challengers. One guy has a C7 Vette. If you don't make 600+ rwhp, you are the slow guy. A few making north of 1000rwhp. They also race at drag strip, and a few go to the 1/2 mile air strip attacks. Guy with the Vette runs 180 MPH in the 1/2 mile.lol no i dont, but if i would, i probably get a car ment for that (even then i would not go that fast on streets nor hwy) what are they driving?
then again the trx 118mph could not be enough to follow them ?
Growing up on crotch rockets (now Harleys) and mustangs i will say these trucks aren't designed for crazy speeds105 on highway is reckless driving. Stopping distance calculates to over 900 feet. Anything goes wrong the charge should be attempted premediated murder. Slow down. The life y'all save just might be mine.
