The Helpful Badger
- Dec 7, 2020
So I bought a Jayco 24MBH which I am going to pull with my 2020 RAM 1500 Classic SLT/Warlock (5.7L Hemi). It's got a 3.21 gear ratio and the RAM towing capacity VIN lookup says I can pull a max of 8,220lbs. I have a 1200lb weight distribution hitch installed. The GVWR of the Jayco is 7350lbs, 5653lbs dry.
I don't suspect I'll have any issues pulling this. I have a wife and son, and will be moving across country soon (PNW to East coast) and will be carrying some stuff with us (not a whole bunch, but likely important items which might weigh at most 200lbs.
I have a trailer brake controller on the way which I'll install here in the next week or so, which means I've not been able to get the RV to a CAT scale or anything to give specific weights yet.
Just basically really want to make sure I didn't screw myself.
Also, could use some help decoding this information:
On the Ram site, it says my max tow is 8,220. On this spec sheet I think it is indicating that if I have a weight distribution hitch that I could theoretically tow 10,200lbs.
-R
VIN Decoder - DodgeForum.com
Dodge VIN Decoder - Decode your vehicle identification number
dodgeforum.com
-R
