drchris1978
 - Oct 10, 2020
$699, is that for front and rear or just fronts?
The 6112s are only the two front coilovers, for the rears you would either have to get 5100s or 5160s$699, is that for front and rear or just fronts?
Im waiting on getting my ORP springs from the dealer as my BTS didnt come with them. When they replace them im having them throw on my 5100s and when I get the 6112s ill just replace the whole assemblyCool, I wonder how much the top hat parts would be. The 6112s are only a tube, perch, and coil. You can disassemble your stock struts and reuse the top hat assembly, but the 6112 is not a full coil over.
I may be interested in building a 6112 coil over and selling my 5100 fully assembled struts.
I don’t know what to till you this is directly from bilsteins websiteThat chart is sure confusing... the ORP/Rebel spring is taller, so I would have guessed #7 and #8 are DO NOT USE, and those numbers would have shifted down. Stock height would be at the bottom. Maybe I’m missing something...
The 6112s are the same concept as the 5100s. The listed gains are over stock, so if you have a ORP truck on setting #8 you will gain 2” over the extra 1” you already have with a ORP springs. The max you can gain with the 5100s on a ORP truck is 2” on setting #5. Im guessing stock UCAs were taken into consideration with this and you should be ok with either stock or Mopar armsYep, caught me mid-edit. Seems like the chart may be edited later, or they have a different 6112 coil for each of the 4 options. I’ll be interested to learn more once they’re available.
what website?So it looks like the 6112’s are now available. Price is $799 per pair on their website!
				I contacted Bilstein directly last week and they emailed me Monday and said they’re available on their website. I did a google search and found the a little cheaper here:
Bilstein 47-293540 Front B8 6112 Kit Ram 1500 – ShockWarehouse
Bilstein B8 6112 leveling kits are designed to provide more ground clearance, allow for larger tires, and increase wheel travel. Multiple snap-ring grooves in the body allow for different spring seat positions, providing 0-2.75 inches of front lift (depending on application). These kits consist...www.shockwarehouse.com
I contacted shockwarehouse about the availability and their customer service said they are basically available as a preorder, they dont have them in stock yet but will ship them as they become available. The CS said most likely first week in NovI contacted Bilstein directly last week and they emailed me Monday and said they’re available on their website. I did a google search and found the a little cheaper here:
Anyone plan to build these into a full coilover instead of re-using your existing springs, etc? Just throwing that out there because I have not looked into what exactly is needed and what it would cost. I'm leaning toward an Icon kit... so I'm curious how this would compare in quality and ride performance.
