PorBoy
^^^. No chance that they have a break in period to allow more mobility ?
That sounds right to me. It's what I did but I already had the orp. I'm running 275 65 20s thoughGuys forgive me for beating a dead horse....I've read the entire thread but I am still a bit confused. If I am going Bilsteins set at 5 and add ORP Springs (front and rear) I should be about 3" taller up front and 1" taller out back?
Also should I add the Mopar control arms for a little more piece of mind?
I have a stock 4x4 Laramie with 275/70/18
Had 5100s put on my orp yesterday- fronts only for A 2” level.
The good: The stance looks 100x better.
The bad: I’m really disappointed in how stiff it rides. Small cracks and bumps in the road Are felt throughout the truck. Took the cush ride of the oem struts and replaced it with a rigid dump truck feel.
Anyone else have this experience?
What setting did you use? I'm assuming #5? Truck looks great, can't wait to get mine delivered and installed!
Thank youYou've got it. The Mopar UCAs are cheap insurance.
Because that's what I wanted to do with mine. You're more than welcome to set yours up as you like.Why would you do this? You'd be better off setting the 5100s at the 5th setting with ORP springs and a cheap .5" spacer from Motofab? Also his front to rear height may vary from yours depending on what options he ordered on the truck. All of these trucks are different and should be measured pre lift install.
Sounds perfectly logical to me. Interested to hear how your ride is after the rear 1.5” rear spacer.Yeah, that will work. With the ORP springs, 5100s on position 2 and the ReadyLift top spacer you will be right at the 3.5". The rear should be fine to leave in place. I don't have a rear lift as. I wanted to see where the front was sitting before I ordered one. With that setup, the front is sitting around 0.5" higher than the rear. So I just ordered a 1.5" rear spacer.
I am interested in others opinions about the ride quality after installing the Bilsteins. If my truck is going to ride terrible, I am not going to do it. This is the first complaint I’ve read about the ride. My truck rides great the way it is nowHad 5100s put on my orp yesterday- fronts only for A 2” level.
I’ve got the 5100’s with ORP PACKAGE. I think it rides incredibly smooth. I noticed less float in the new set up. I still have stock tires though. If I move to 34” e rated tires I, sure it will transmit more bumps with the stiffer rubber compound.I am interested in others opinions about the ride quality after installing the Bilsteins. If my truck is going to ride terrible, I am not going to do it. This is the first complaint I’ve read about the ride. My truck rides great the way it is now
Ok, guess you took that the wrong way. I'm curious as to the reasoning behind your method of lift? Why would you choose a hardened spacer over tuned suspension travel? Maybe I'm missing something.Because that's what I wanted to do with mine. You're more than welcome to set yours up as you like.
And I never said that anyone else's would be identical. I simply stated what I did with mine.
Apologies, I must have taken the way it was wrote with different intent.Ok, guess you took that the wrong way. I'm curious as to the reasoning behind your method of lift? Why would you choose a hardened spacer over tuned suspension travel? Maybe I'm missing something.
I never mentioned you saying his truck would be identical. Was just letting anyone know that most of the Rams front to rear heights are different.
I like your description of less float but smooth. Dead on.I’ve got the 5100’s with ORP PACKAGE. I think it rides incredibly smooth. I noticed less float in the new set up. I still have stock tires though. If I move to 34” e rated tires I, sure it will transmit more bumps with the stiffer rubber compound.
Hello all just picked up a 2019 big horn and interested in leveling out the front, are the 5100s a better option then the updated mopar kit?
Oh so the mopar kit raises the rear as well?the Mopar kit isn’t a leveling kit, rather a lift kit. However, it would seem from most people that with the mopar kit you maintain quiet a bit of the factory rake, so keep that in mind.
If you are wanting purely just a level, I would say bilsteins are the way to go.
YepOh so the mopar kit raises the rear as well?
