dougf
My factory ordered 2020 Ram 1500 Limited is due to arrive any day now.
Options:
5.7 Hemi E-torque
3.92 axle
Electronic locking rear axle
Off-road group
Trailer brake control
Rambox
MF tailgate
Bed utility group
Limited Level 1 equipment group
33gal fuel tank
When I spec'd this out prior to order using the towing tow guide at RamTrucks.com, it listed tow capacity of 11,220 and payload 1770. I plan to tow ~4500lb dry weight, gvwr 7500 trailer, so I thought it would be well within the trucks capability. I will only be towing 2 or 3 times a year, interstate up to 1000 miles round trip, mostly interstate (although I generally don't exceed 65mph when towing.) Otherwise, the truck will be used locally for light duty and some long (non-towing) trips now and then.
Here is the surprise. Once the VIN was available, I used the Ramtrucks.com towing guide and looked up my new truck by VIN and got a big surprise. Tow capacity of 10900 (just fine), but PAYLOAD listed a 1009lb! Wow. I lost 700lb payload somewhere with all the options. With a tongue weight of ~600lb, tank of gas ~240lb, and my wife and I at ~320lb, I've already exceeded payload without ANY cargo loaded into the bed. How dangerous is it to load an extra 100-200lbs in the bed since I'm already exceeding the limit when empty? This is a BIG disappointment I wasn't counting on.
Options:
5.7 Hemi E-torque
3.92 axle
Off-road group
Rambox
MF tailgate
Bed utility group
33gal fuel tank
