Oh yeah look underneath plenty of spotsWould these accesss be able to fit a CB antenna fitting through?
Unfortunately no, its not going to work if you do that. Someone has already tried to get around having to do it the way the instructions say and it didn't work.ok so i purchased the ram cargo lights off ebay. can i just wire them into the hot wire without going thru all the steps to wire them under the dash ? then going to the dealer to hook it up to their scanner so it works . new to the ram world but love my new truck so far thanks !
well crap ok will do it the right way .doesnt sound too bad just thought i would take a shortcutUnfortunately no, its not going to work if you do that. Someone has already tried to get around having to do it the way the instructions say and it didn't work.
I'd like to do it this way. I went with the Mictuning strip lighting on Amazon. On the trailer harness I'm guessing there is constant power (hot wire) to the 12 o'clock pin on the 7-pin? Want to make sure I have that correct. This seems to be the easiest install and I don't care about the turning on and off. Thanks!This is an awesome post that I’ll need to save in case I want to do this “right” in the future. In the meantime:
I have a tonneau cover and I find that I need to turn the bed lights on very often while at the rear of my truck, so I went the easy route...
I purchased the lights from Amazon at the link below and wired them to my trailer harness by the spare tire. It has a weather resistant push button that I adhered to the bottom of my tonneau rail. I love it and it only cost me $25. I must remember to turn them off, but that’s no biggie.
https://www.amazon.com/gp/product/B073ZGNDTC/ref=oh_aui_detailpage_o08_s00?ie=UTF8&psc=1
The 1 O’clock postion in the 7 pin plug is battery charge for the trailer, and yes it powers up with the ignition. If you’re just going to plug it in to the 7 pin plug I’d use the 11 O’clock position which comes on with your marker lights, the reason I’d use that one is because your marker lights only come on when it’s dark so your bed lights won’t be on all the time.I'd like to do it this way. I went with the Mictuning strip lighting on Amazon. On the trailer harness I'm guessing there is constant power (hot wire) to the 12 o'clock pin on the 7-pin? Want to make sure I have that correct. This seems to be the easiest install and I don't care about the turning on and off. Thanks!
Correct. The pins are labeled on the cover of the trailer connector. I used the constant power and negative (I believe that they were red and white respectively). SUPER simple.I'd like to do it this way. I went with the Mictuning strip lighting on Amazon. On the trailer harness I'm guessing there is constant power (hot wire) to the 12 o'clock pin on the 7-pin? Want to make sure I have that correct. This seems to be the easiest install and I don't care about the turning on and off. Thanks!
No, unfortunately that wire is only on the interior of the truck. It runs down the interior sill plates and up the c pillar to the third brake light.Is there a way to tap into the white/tan wire towards the back of the cab or under the truck so you don't have to go through the floor and take off the sill plate to install?
Nice install. I plan on doing the same thing since it's so cheap. I haven't taken a look at my truck yet, but where did you run the wires through to get them under the bed? Do you have any pictures of where you tapped into for the power? Anything else I should purchase as well? I have plenty of wire laying around but figured I might need some double sided tape for the switch. Also, I just had a drop-in liner installed and hope it won't interfere with me running the wires.
Thanks for the help.
No problem man. Let me know if you need anything else.Thank you, RodRow! Extremely helpful.
Where did you ground it? and have you changed your cargo lights to led?I had zero luck running my lights and connecting to that same wire. I’m trying to figure out what I did wrong here
Cargo lights are not LED. I tried multiple spots along the underside of the bed to ground it with zero luck. I hooked the lights up to a battery and they are working fineWhere did you ground it? and have you changed your cargo lights to led?
If you have a test light I would test that wire to make sure it’s the right one, other than that the only difference is I changed out my cargo bulbs to led.Cargo lights are not LED. I tried multiple spots along the underside of the bed to ground it with zero luck. I hooked the lights up to a battery and they are working fine
I tested them on a battery and everything worked. I just changed the cargo lights out to LEDs and I will reconnect everything else tomorrow morning and see if they work. Now it’s time to drink a beer and question my life choices!If you have a test light I would test that wire to make sure it’s the right one, other than that the only difference is I changed out my cargo bulbs to led.
