Bansheeman6100
- Apr 15, 2022
So what are you recommending? 2 sets of the D4S, skip the rear tweeters and use one of their amps?
yeah option 2 comes with the adaptors for the tweeters to go in the place of the factory mids in the dash corners. front center is not really needed IMO with the dsr1 dsp you get time alignment for staging. i went all out with that setup it gets louder than most want to get. crew cab has alot of enclosure options if you have quad cab fox acoustics is really the only wat to go. i have a quad cab it's pretty loud and clear with alot of bass. i like it the infinity's got great reviews on amazon from ram owners i guy with the alpine system complained i guarantee it's because he kept the factory alpine amp. my door 6.5's are 2 + 7/8 i believe the 3 inch would not be a problem.
i don't want to step on toes but my friend at work has a 2023 that had that alpine or the harmon with the headliner speakers we thought it was not up to our par so. he dropped his truck off at a good shop in my area paid 5k for a all jl setup. custom box for 2 jl 10's rear doors front components and a 900 dollar jl 5 channel amp kept the 8.5 screen. sounds pretty good at 5k i hope so. he thinks mine sounds better i got about 1600 in mine but i did my own install if i had the money i would have just paid to have it done with my equipment. i would not add headliner speakers. he abandoned the center and headliner speakers.
i look like a D4S fan boy lol i have been a fosgate guy for over 25 years. quality and price D4S is hard to beat
i got this amp for 250 and it's unblameable. very powerful. as in i can't believe it's a 5 channel that is doing it all. look at the measurements and break out a tape measure. the pick makes it look huge but it's not really that big.
Down4Sound JP95 RED | 1500W RMS - 5 Channel Amplifier
www.down4soundshop.com
you have a crew cab so you have alot of room IMO but the e torque battery limits the amp mounting mine is where the battery would go. i mounted my amp behind the back seat you can't see it at all. as far as storage i have a hard bed cover and a bed so i didn't care about that however i get it some people want some under seat storage. with a quad cab that box in my truck that looks huge is only 2 cubic feet the minimum for my woofers the only thing i could find that would work in that space was Sundown. sounds like you should go with a 8 or a 10 really the 8 will work out best for space if that's a big concern. i went with the infinity's in the rear doors and the component's up front to be honest if no one is gonna be in the rear i would leave them out. if someone is in the back seat you most likely not going to have the music on at least i don't because normally there is conservation happening and music taste vairy so much. over the years i almost always delete rear speakers. plus that way a 4 channel amp can run the woofer bridged and the 2 channels left run the front. D4S has 1 more tiny powerhouse the JP3. it's super powerful and compact for a sub but you can go with alot of brands that will do the job. you could get this and a sundown 8 or go with the 10 set up i think you will be quite happy with the 8 though. if you go 4 channel this is good jp84. i think you should got to a reputable shop for the install unless you really confident i have done many installs and once worked at a car audio dealer installing so i did mine and it was a PIA. you should go with a small efficient amp it don't need to be super powerfull i'm thinking jp84. if you get a dsr1 it has a optional and bass knob.
dsr1 350
box 265
woofer 129
rca's and wire let's budget 100
6x9 70
componets 250.
amp?
=$1164 plus install and whatever amp you choose. it will sound lovely!
BLACK 8" SINGLE PORTED SUB BOX, FITS 19-26 DODGE RAM 1500 CREW-CAB
Ground-shaker is a leading speaker box company in Southern and Northern California with an objective to strive into a worldwide speaker box companywww.ground-shaker.com
Sundown Audio 600W Peak Dual 2 Ohm VC E Series V.6 8" Car Subwoofer E-V.6-8-D2
Heavily vented magnetic gap Solid pole piece for extremely high thermal power handling Spring Loaded Terminals RMS Power = 300-watts Dimensions: 12"x12"x12" This Item Includes: (1) Sundown Audio 600W Peak Dual 2 Ohm VC E Series V.6 8" Car Subwoofer E-V.6-8-D2 The E8 v.1 was the FIRST subwoofer...bigjeffaudio.comDown4Sound Shop
Buy Car Audio Online the real #1 Source, Fast Free Shipping, EZ Financing, Price Match Guarantee, freebies in every order, Shop Now!www.down4soundshop.com
I ordered 2 pairs of the Infinity 6x9 and a pair of Infinity 3.5s for the dash. Looking at the anc bypass harness, there is a PAC ANC-CH01 for $27 or an Idatalink bch3. for $15 (or $10 at Crutchfield but you have to pay shipping, but you do get an install sheet for speakers) It appears the Idatalink does the same thing as far as bypass goes but the PAC allows you to run amplified speaker outputs bypassing the ANC so if you are adding an amp the PAC is the way to go. It only allows for 4 speakers and I got 6 but I'm assuming the fronts will go to the front door and the dash, does this assumption seem correct? I don't plan on adding an amp now but may in the future. wonder how it would sound with using speaker level inputs amped right there under the front seat. would you still need a signal processor? No room for a sub, I load my backseat area up with tools all the time.
Here you go , plug and play KenwoodI just want better sounding speakers and more volume. I don't want to learn how to do all the stuff talked about with with "270 uf cap for the 3032 is a bass blocker which gives a crossover point of 196 Hz at 6 db per octave."![]()
If anyone comes up with a "remove these old ****ty speakers and put new ones in" setup, I'm all ears!
