- Feb 24, 2018
- Solutions
- 1
- Location
- Central Pennsylvania
Interesting. Their brochure, which does have weights, does not list a 2550BHS
I meant on the sticker. The base weight and the payload capacity should add up to the gross. The axles have a capacity of 4000lbs each...the gross is 8800...800 pounds more than both axles.
The dry capacity just doesnt make sense compared to the max.
Sad thing is I see many travel trailer stickers where they state the GVWR being higher than the GAWR can support
Well first of all you won’t be able to max that trailer weight to 8800 lbs because according to your pic the axles are only rated to 4000 lbs each or 8000 lbs total. Second I would be shocked if you added 2k worth of gear and supplies. I would think 1500 or less. But it still comes back to the fact that your truck doesn’t have enough payload.
