rjaxin
- Sep 8, 2024
My 2021 1500 Limited has had issues with the backup camera cutting in and out. I got a camera module from a wrecker (after getting a quote for $1000 CAD from Dealer!!!), but its not the camera itself. I tracked the issue back to the connector for the small coax cable underneath the tailgate. It is a removable connector so you can remove the tailgate (which we have never done previously). If I put pressure on the left-side/truck-side of this cable, the video signal is good, but on its own, the connector does seem to stay in firm enough.
I can try replacing the wiring harness: https://store.mopar.com/oem-parts/mopar-jumper-wiring-68488448aa, but was thinking if this is a common connector, it may be easier to just run a 2nd wire. It looks like a small coax - is this a Farka connector? If so, which variation?
-Rob
-Rob
