U
User_3336
Guest
Good afternoon reading!Yea, the oil wars on here crack me up!
My Father in law worked on the engineering team in the early 2000, that designed the third Gen 5.7 . He was very insistent that the only reason they changed the weight of the oil, was for fuel economy.
I thought it best not to question him on this. He was the Mechanic Engineer, I’m just an Electrical Engineer. To keep things happy in the family, I have alway used Full Synthetic SAE 5W-30 Motor Oil. This is what he insisted was the only correct oil for “his” engine.
Was his position dated? I don’t know. He had retired before this change was implemented. He has recently passed away. Out of respect, I will alway use Synthetic SAE 5W-30 Motor Oil in my truck. I will say that I have never experienced any adverse effects from this. The truck had 500 miles, before I changed to the new oil. I’m just a little over 20k now. Time will tell if this is/was a mistake.
Sharing this anecdotally, not trying to sway anyone from their choice of motor oil.
Neither my '20 nor '22 manual have that chart. They used to be commonplace, but the powers that be don't want us to be informed or make our own choicesTo this point: Did they change the owners manual?
Someone recently recommended I switch from 5w-20 to 5w-30. I vaguely remember in the owners manual there WAS (not any longer) an oil viscosity chart based on operating temperature conditions.
Mysteriously...I can't find it. As you know, the owners manuals are online now. There were grumblings I found on other forums about Mopar changing the owners manual and removing the 5w-30 approval due to the EPA/government being PITA's.
Am I losing my mind or did this exist at one point in time?
Yes it changed and no you're not losing your mind
Here is an example from the 2014 owners manual
And note how they recommend 5w-30 in the 2500 variant when towing gets past 7000-ish pounds
If I am reading the 2014 manual correctly, it still says 5w20 is the preferred viscosity and that 5w30 may be used when 5w20 is not available.
I'll never put anything back in except Pennzoil Platinum 5w-30! Truck seems to run
so much better and no clatter on startup anymore!
Same here. I add lubegard every change. Makes me warm and fuzzy inside every oil change like my lifters are indestructible! Haven't looked back.I'll never put anything back in except Pennzoil Platinum 5w-30! Truck seems to run
My reading abilities are pretty good and that's not how I read it. Keep beating that dead horse . . . .What it says, reading between the lines, is that running 5w-30 is better for the engine.
I always say good morning to my lifters and cam as well.
Never exceed the full mark on your dipstick. If you feel the need to include additives, reduce the amount of oil you add by the amount of additive you'll be pouring in.Where are you finding the LubeGard? I can't seem to find online?
And are you adding it to compliment the recommended 7 qts? Or filling to 7qts on the dot with the LubeGard?
You guys don't know what you are talking about. Everyone knows that you should run 20w50 all season!
Good thing nobody brought a gun to this discussion.90w severe gear all the way.
