Any Ram Care folks still on this forum?
azzx
Central AZ
Need to ask a few questions about my 2025 that my dealer is clueless about!
mikeru82
5thGenRams Supporter
The Palouse
Ramcares is here to help facilitate between an owner and a dealership they are working with. They aren't known to give technical support for our trucks. But as @CHeYeNNe71 illustrated, you can get their attention by tagging @RamCares in your post. Or you can send them a message directly by clicking on their username then clicking the "Start conversation" button.
Scram1500
What questions are they clueless about?
azzx
Central AZ
the push button stop/start does not have an ACC position. only off and on/run.
So when it is on on/run, all accessories are on.
so if I want to sit in the truck and listen to the radio, all accessories are on.
mikeru82
The Palouse
That won't hurt anything other than run your battery down if you keep it on long enough. You didn't want to do that back in the day but it's fine on modern cars and trucks.
KMach
Try holding the start button with your foot off the brake for atleast 10 seconds. Might work. GM is like this.
azzx
Central AZ
Tried - no go
thanks
This is just dumb and makes no sense to remove this feature
mikeru82
The Palouse
What is your concern with having the truck in on/run position?
azzx
Central AZ
everything except engine is on
I can turn-off ac and other stuff - however, don't see a benefit from RAM removing this basic function!
mikeru82
The Palouse
I'm not sure how they would have an ACC position with a push button other than to go with a more complex one. Every vehicle I've owned with a push button worked the same way. Change the settings for how long your radio stays on after shutting the truck off to max, which I believe is 15 minutes. If you need it to stay on longer you can turn the truck on then off for another 15 minute session.
Jimmy07
Honorary Site Supporter
The 2020 ram in your signature has an ACC position on your push button:
Even other vehicles that don’t have an ACC position that you pass while getting to the run position like the Rams, you can still get to the ACC ignition on by pressing and holding the start button with foot off brake.
With the 2025 Ram (and wagoneers and grand Cherokees with the new CAN architecture), there is flat out no ACC ignition position, nor are there any ACC ignition relay circuits on either of the power distribution centers. There are only run relay, and run/start relay circuits.
Brutal_HO
The Mad Irishman
Douglas County, CO
:eek:
Threadjack; is it usual for a Start button to crack/split with only 4 years/17K on it?
