Any issues with 37 in tires with the 3.92s?
Well the 37s arrived and were installed today. Much happier! Had an hour and fifteen minute drive home no difference in shifting, braking, power loss or trying to find 8th gear everything is working as good as it was with the 35s. Only thing I did was recalculate my speedometer with my Taser DT, all set! I appreciate all your guys's inputs and feedbacks!!! I am much happier with these now if only I can get them poked out a little more...LOL thinking of a 1in hubcentric wheel spacers I have 1-1/2" I may try but I believe I'll have issues. Unless you all have any input on that? I do need to get a set of rims for the 35s that I will run in the winter for this thing. Hopefully I can just get a set of 20 x 9 Ram OEM wheels that will work and use the spacers to get me through the winter. I don't know if I will get any rubbing with the 1" on the 37s just want a little bit more aggressive without buying new rims, bad enough I spent over 3500.00 on two sets of tires within a few months LOL don't need another set of rims on top of that. but needless to say everything is great it's filled the wheel wells and looks alot better besides truck being dirty. I'm impressed with them! Thanks again!
God I loved this thread! I'm in the market for 6in RC lift, 20x12 tis wheels with -44 offset and 37s. I was so on the fence cause I was worried about my 321 gears but after reading this, I'm doing it! I saw someone saying that they rub some but do you think they would with my 6in lift, 37s and -44 offset?
They will definitely rub. I’ve got a BDS 6” lift with 20x10 -25 wheels and 37” Falken Wildpeaks and I rub with that setup. Had to grind down some of the pinch weld on the backside and push out the fender liners on the front. Rubbing would be horrendous with 20x12.
Today I actually just pulled the trigger. Went 20x10 with -25 offset. 37sIMG_5239.jpeg
