Summer air is heavier because of humidity.Depends if it’s winter air or summer air.
Cold air is heavier. That's why hot air rises.Summer air is heavier because of humidity.![]()
Wait, so there is a weight limit on these trucks? Other than the rubber stops....
It's thinner. Me too... I figure that thinness is worth maybe 23 mpg vs that thick humid midwest air... Of course that is not completely accurate as it is the lyometer reading.I use high altitude air.
OK, NOW I know how to maximize gas mileage. Helium filled tires, live at 10,000 feet, only use summer gas 91 grade, never put anything in the truck, 3.21 gears, e-torque, road tires, and only go places where you can go both ways downhill with a tailwind.Or, just fill all the tires with helium!Then you can increase your payload
Always looking to help a brother outOK, NOW I know how to maximize gas mileage. Helium filled tires, live at 10,000 feet, only use summer gas 91 grade, never put anything in the truck, 3.21 gears, e-torque, road tires, and only go places where you can go both ways downhill with a tailwind.
I'm set now, thanks for the advice on the Helium.
Don't forget that when you're towing, put everything in the trailer, including the truck.OK, NOW I know how to maximize gas mileage. Helium filled tires, live at 10,000 feet, only use summer gas 91 grade, never put anything in the truck, 3.21 gears, e-torque, road tires, and only go places where you can go both ways downhill with a tailwind.
You truck displays a soap reading?Of course that is not completely accurate as it is the lyometer reading.
Man, if he had just remembered to install his WDH first....
I got 23% off MSRP plus top dollar on my trade. That was of course 2 yrs ago though.I put a build order in and got 13% under MSRP, before tax, title registration, etc. Deals can still be had. No trade in.
