silver billet
- Apr 18, 2019
This will differ from truck to truck, some of the biggest factors will be:
1) The octane fuel you are using. The engine will tend to go into ECO/MDS mode more when you are using 89-91 octane fuel since the engine is optimized to run at 89 octane fuel and does not have to advance or retard the timing.
2) The differential that is in your truck. at higher speeds a truck with a 3.21 rear end with have lower RPM's at higher speeds and will be able to go into ECO/MDS mode more often at highway speeds than someone with a 3.92 rear end.
3) Using the cruise control tends to be a little aggressive and the truck will not kick into ECO/MDS mode as often as when you control the gas pedal manually.
I'm not actually sure about point #2. The engine makes more power at higher rpms, thereby possibly being able to stay in MDS longer. However in terms of MPG savings, it still appears to be better to run at lower RPMs than at higher RPMs, even if MDS is not active as often. Best trip I've recorded was 25 mpg with MDS disabled on the entire 3 hour freeway trip, so whatever MDS is actually doing in terms of saving fuel, it isn't anything to write home about.
