I would like to thank all of my truck bros, for broing on trucks and allowing us to reach this most prestigious milestone. You're all completely ridiculous and I love you for it.
#NoLiftLifeFood for the thought.
If you have 3.92s and install 35in or larger tires, didn’t you just essentially turn your superior truck into a truck with 3.21s and stock tires when it comes to rpm to speed ratio and off the line feeling?
Wonder how many posts we could get out of an Android vs. Apple thread.![]()
Which gear in the Android and Apple?Wonder how many posts we could get out of an Android vs. Apple thread.![]()
Android with 3.21 is far superior to the Apple with the 3.92.
Apple with 3.21 almost as good as Android with 3.21. Android with 3.92 worse than Apple with 3.92, now if the Android has etorque, all bets are off but if the Apple has the eco with 3.55, it's superior to all
When I put 325/60/20's on my last Ram it effectively made the gear ratio 3.73's so still a lot better than the 3.21's...Food for the thought.
Going from 32" tires to 35's should have netted you a 3.56 ratio. My 33's turned my 3.92's into a 3.79.When I put 325/60/20's on my last Ram it effectively made the gear ratio 3.73's so still a lot better than the 3.21's...![]()
My Note 9 with a 3.92 gets 36-48 hours on a charge with moderate use and can pull a 4GB app without breaking a sweat.Which gear in the Android and Apple?
Literally the best phone ever.My Note 9 with a 3.92 gets 36-48 hours on a charge with moderate use and can pull a 4GB app without breaking a sweat.
That would be true if 35 inch tires were 35 inches and not 34 or 34.2 inches...Going from 32" tires to 35's should have netted you a 3.56 ratio. My 33's turned my 3.92's into a 3.79.
Gear Ratio Calculator
Easy to use gear ratio calculator. Use our gear ratio calculator to find the correct gear ratio to run when changing tire sizes to keep your stock gearing.tiresize.com
It's all relative. The stock 32's are smaller than 32".That would be true if 35 inch tires were 35 inches and not 34 or 34.2 inches...
There was plenty of weight added... Plenty! Lol
That's no lie, you can feel and see tire weight.
I went from street tires to drag radials on my car and lost 10 rwhp on the dyno. Couldn't feel it because of how much power the car makes but you could see it on the dyno and at the track
Yes they are, every time I drive this truck is a treatYeah, going from my lifted '15 to this new Limited is a completely different driving experience. These 5th gens are so damn smooth.
