So there's a lot here with controlling the sound stage and the speakers and the equalization. The DSP will help you do that but you will have limitations if you're running a passive component set in the front and a full range, three-way speaker in the rear.
I'll start with the three-way speaker in the rear, that speaker is effectively going to be playing lows and highs so you will need to create a bandpass filter for that speaker or feed it full range signal and rely purely on time alignment to help set the appropriate amount of rear fill.
The tough part on your front stage will be if you plan to use the passive crossovers included with the component set. The passive crossover is already have their high and low frequency and response curve set from the factory. Using the DSP you will be able to do some mild EQ in the time alignment to correct the sound stage but you will struggle due to those existing factory EQ points. AKA you don't have complete control of the component set.
Now using a 6 channel amplifier you could take complete control of your front stage and rear stage using the DSP and the 6 channels AKA going completely active. This is a slippery slope and can take a long time to tune and is also a great way to fry drivers if you aren't quite sure what you're doing as far as crossovers and gain settings on the amplifier.
The best way to utilize the DSP as a novice and avoid all of these risks is to create some simple high pass and low pass filters for your speakers and subwoofers. Then you can use the time alignment left right front and rear to help set the stage in the correct location. No shame in doing that and learning how to use those tools first before diving into controlling each individual driver independently.
If this is something you really want to dive into I encourage you to take a look at the DIY Mobile audio community that exists. There are tons of folks on that that have vast experience in the industry and tuning systems.
Sent from my LM-G820 using Tapatalk
I’ve been meaning to reply to this for the last couple days, but kept getting busy every time I thought about typing it out.
After I had the new amp/DSP installed for a couple weeks, had been trying to figure out what works for me, why I wasn’t getting the sound I wanted, how to adjust things, etc, i came back to this post, and it really made a lot of sense. I had installed the tweeters with the passive crossovers. then, based on youtube install videos, I set up crossovers right away on the app, which basically blocked all the highs, so i wasn’t getting anything out of them, and couldn’t figure out why. once I figured that out, I removed the passives, and had a massive improvement. Now, I’m playing with the electronic crossovers, and working little by little with the graphic eq, to cut from the 3-ways in the rear so they don’t dominate everything, and remove the muddy sounds from the mids. The tweets aren’t as clear as I’d like, and I still want to try and move the stage further up, but I’m getting an idea of what I’m doing, and it’s sounding better.
still waiting on my enclosure to get here, so don’t want to get too dialed in, then have to re-do everything, so really focusing on what changes what, and what effect everything has. Once the build is done, then I’ll really work on tuning more.
anyway, thanks again for this post. Great info and advice, much appreciated!!
