Interesting - Crutchfield says that's not a fit for my Ram.
So, I finishing my install last night and promised to follow up after I was done.  Here's a summary of how it went including some details that I think might benefit someone in the future.
Rant/Initial Review
Overall, the install was easy once I got the correct harness. However, I don't like anything I've heard coming from the JL Audio Stealthbox with the two 10s, powered by the Audio Control LC1.800.  I don't know if it's just the nature of a compact subwoofer, or the form fitting box, or the fact that the subs in this box are firing straight into the floor... but this setup just does not fill the cab with balanced sound.. I can hardly hear any bass in the front seats at all - the stock 8" subwoofer filled the cab with more bass than the Stealthbox does. I've tried both phases, so it's not a phase conflict issue. I've tried feeding signals from the L/R rear door channels to the amp, and then I switched to using one of the three signals going to the OEM subwoofer. Not much of a difference between the two signal sources.  I can hear nice and full sounding bass if I put my ear right next to the box, but that bass doesn't make it to the front of the cab.  I might have to return the Stealthbox and look into the ported boxes from Fox Acoustics if I can't get proper sound out of the JL Audio Stealthbox.
For reference, my expectations are set by the single 12" Kicker Solo-Baric L7 (~700W RMS) that I have in a sealed box in my 4Runner. The JL Audio Stealthbox with it's 800W RMS just doesn't even come close, and for $1500, I expected WAY more.
The good news is that the rest of the Alpine system keeps up very well and actually sounds pretty good when you set the bass to -3 or -4 on the head unit.
Now, onto the install details...
The PAC APH-CH03 is the correct harness to use if you have the Alpine system. Using it allowed me to disable the stock subwoofer behind the rear seat, bypass the ANC (supposedly - I have no way of knowing whether this is working as intended or not), and provide me with an easy place to pull L/R speaker level signals (or the OEM subwoofer signals) to feed my subwoofer amplifier, all from under the drivers seat without having to touch any OEM wiring.
The APH-CH03 harness comes with two male and female "breakout" harnesses that plug into the two grey OEM connectors under the seat. These breakout harnesses allow you to connect the factory speakers to an aftermarket amp, or connect them to the OEM amp.  It's a good idea to plug the female grey harness into the male grey OEM harness and tone out which pairs go to which speaker, but here is how mine were mapped in my '19 Rebel. (These are the colors of the PAC APH-CH03 harness):
| Speaker 1 (Red) | Front left dash |
| Speaker 2 (Orange) | Front right dash |
| Speaker 3 (Yellow) | Front left door |
| Speaker 4 (Green) | Front right door |
| Speaker 5 (Blue) | Subwoofer |
| Speaker 6 (Purple) | Subwoofer |
| Speaker 7 (Pink) | Subwoofer |
| Speaker 8 (Light Green) | Front center dash |
| Speaker 9 (White) | Right rear headboard |
| Speaker 10 (Gray) | Left rear headboard |
| Speaker 11 (Brown) | Right rear door |
| Speaker 12 (Black) | Left rear door |
