Alpharex Headlight Group Buy - Ends 04/30/20!
Whatever he pushed down on to release the panel, I don’t have that. Tried pulling out and down and no joy. Bolt is definitely out.
It looks like it's the bracket that the the panel snaps into, it should be right below the flange you removed the bolt from.
Thanks dts828, I will look again. That sucker sure is in there for anyone else trying to get this off.
Sure will. And, once you know where that little tab is, it's much easier to get the trim panel off. Just waiting on FEDEX know to get the lights in.
So do we need to purchase any extra wiring or taps or do the lights come with all of that?
FedEx didn't come today, so I guess it will have to wait until Wednesday. LED's should be here then too.
My headlights did not come with the micro2 fuse tap needed for the DRLs but napa had it plus an extra 20 amp fuse for the tap. They work great only waiting on the LED bulbs.
I wasn’t sure what to do with the side marker so I just tucked it by the fender and zip tied it.
I take IT DRL stands for Daytime running lights? What I Am asking is when I receive my lights and start the install am I gonna have to do something different to activate the LED DRL lights.
By the way yours look awesome did you go with a black or jet black?
Yes, DRL = Daytime running lights.
If you have stock halogens then yes, you will have to tap into a fuse for the DRLs.
If you have stock LEDs then you're good, just plug and play.
The wiring harness for the DRL is very easy to install and you will get instructions in the box for that.
Yes, and it does come with a harness that is pretty straight forward, you plug one end to the new headlights and the other end to the batery (red to positive and black to ground), you will be left with a grey wire that needs to go to the fuse box i believe its fuse F60 (this is where you need the fuse tap, make sure its a micro2 fuse tap). Once you wire that The DRLs will work automatically.
My lights did not come with instructions, but I managed.
Thank you so much. I have the Delmonico Red trim. It also has the black grill. I hope it ends up looking good as yours.
I had meant that for the gentleman with the white ram sorry. Thank you all for your input that will be very helpful.
That Delmonico red looks awesome, should look very good with the new headlights
