@azzx Did you ever get this working?Guys,
I have assembled a list of all the OEM parts needed for 360 camera. of course i maybe missing a few things
I would really like to buy the front camera components and install them...
I’m currently using the android app as I personally don’t have a windows pc. With the windows version would I need to pay again for the full version? I can borrow a laptop from my parents if need be for the time being. If i would need to buy the windows version I may just wait a bit until hopefully the app is corrected.Just got word back from Alexey at AlfaOBD...
So he is working on a fix and has made v2.1.5.0 available on his site for download until then.
I don't know the answer to that. Maybe contact Alexey at AlfaOBD and see what can be done.I’m currently using the android app as I personally don’t have a windows pc. With the windows version would I need to pay again for the full version? I can borrow a laptop from my parents if need be for the time being. If i would need to buy the windows version I may just wait a bit until hopefully the app is corrected.
Yeah that’s what I’ll likely do. It’s not something I need right this second.he knows that the issue exists - I would guess it will not be too long before he releases an update to address the problem.
you get a discount, email them.I’m currently using the android app as I personally don’t have a windows pc. With the windows version would I need to pay again for the full version? I can borrow a laptop from my parents if need be for the time being. If i would need to buy the windows version I may just wait a bit until hopefully the app is corrected.
you need an unlocked pcm.Has anyone been able to defeat the speed limiter on a 2020 CTD truck?
I've tried setting the BCM to 200 KPH, 255 KPH, etc. and it falls on its face and limits at 101-ish no matter what. I recall 255 KPH set a CEL. I just saw a post showing @248KPH but I haven't tried that.
I haven't been able to do anything with the ECU settings as AlphOBD complains it doesn't have my ISO, and then setting changes don't work.
FWIW, I was able to enable Trailer TPMS in the EVIC and 12" Uconnect, and we've finally (on another forum) identified all the parts needed to add this to 2019/2020 trucks that have a supported body harness.
try different sizes till you get it right. air pressure and wear both change it as well.Interesting thing. I put my Cooper ATP 275/60/R20’s on Tuesday, and promptly put 800+miles on them . According to Waze, at 75 I was actually doing 78. Today I set them circumference to 2631, which is the best info I could find. Now when I’m doing 75, Waze says I’m doing 72. I followed all the steps and did the resets and cleared error codes. Anyone think of something I missed? Thanks
So I dropped the mm from 2631 to 2595, and it’s within 1MPH of Waze. May drop it another 5mm but your input was right on. Thanks.try different sizes till you get it right. air pressure and wear both change it as well.
Why would you need alfaobd to do that? That can be done with a simple wiring harness and dash kit?I'm curious if using AlfaOBD might let me put in an aftermarket head unit?
Do you have the 12" display? My 2018 ram had the 8" uconnect which I replaced with a pioneer nav unit with no problem and everything functioned perfectly.Was told that an aftermarket head unit would make the truck inoperable
