AlfaOBD
Bradleys
Guys,
I have assembled a list of all the OEM parts needed for 360 camera. of course i maybe missing a few things
@azzx Did you ever get this working?
I would really like to buy the front camera components and install them...
Teamlacalle
Just got word back from Alexey at AlfaOBD...
So he is working on a fix and has made v2.1.5.0 available on his site for download until then.
I’m currently using the android app as I personally don’t have a windows pc. With the windows version would I need to pay again for the full version? I can borrow a laptop from my parents if need be for the time being. If i would need to buy the windows version I may just wait a bit until hopefully the app is corrected.
Apexbasher
Saint Augustine, Florida
I don't know the answer to that. Maybe contact Alexey at AlfaOBD and see what can be done.
Bradleys
he knows that the issue exists - I would guess it will not be too long before he releases an update to address the problem.
Brutal_HO
The Mad Irishman
Douglas County, CO
Has anyone been able to defeat the speed limiter on a 2020 CTD truck?
I've tried setting the BCM to 200 KPH, 255 KPH, etc. and it falls on its face and limits at 101-ish no matter what. I recall 255 KPH set a CEL. I just saw a post showing @248KPH but I haven't tried that.
I haven't been able to do anything with the ECU settings as AlphOBD complains it doesn't have my ISO, and then setting changes don't work.
FWIW, I was able to enable Trailer TPMS in the EVIC and 12" Uconnect, and we've finally (on another forum) identified all the parts needed to add this to 2019/2020 trucks that have a supported body harness.
Aseras
you get a discount, email them.
Aseras
you need an unlocked pcm.
patelraj1225
Has anyone here used Alpha OBD to remove the air suspension sales codes on a 5th gen? I recently removed the air suspension on my rebel, but I cannot find any info on how to remove the sales codes on the 5th gen. If someone with Alpha OBD, can confirm that ability to delete the air suspension sales code, that would be greatly appreciated!
Rhombus
Cedar Park, TX
Interesting thing. I put my Cooper ATP 275/60/R20’s on Tuesday, and promptly put 800+miles on them . According to Waze, at 75 I was actually doing 78. Today I set them circumference to 2631, which is the best info I could find. Now when I’m doing 75, Waze says I’m doing 72. I followed all the steps and did the resets and cleared error codes. Anyone think of something I missed? Thanks
Aseras
try different sizes till you get it right. air pressure and wear both change it as well.
Rhombus
Cedar Park, TX
Aseras. Good point. Once you’ve set it it’s a quick and easy process. I’ll play with some options
Rhombus
Cedar Park, TX
So I dropped the mm from 2631 to 2595, and it’s within 1MPH of Waze. May drop it another 5mm but your input was right on. Thanks.
Aseras
I've been trying to enable the park entry mode for the air suspension. I've got the selection on the screen but I cant toggle it. Any ideas?
FM45
MA
Alpha updated -- 2.1.9.0 pc & 2.1.7.9 droid
-=FM45=-
Hockeygod1225
Was told that an aftermarket head unit would make the truck inoperable
Do you have the 12" display? My 2018 ram had the 8" uconnect which I replaced with a pioneer nav unit with no problem and everything functioned perfectly.
WorkingDad
Just the little 5” uConnect. Good to hear! Just got the truck this week, I’m going to pull the unit out this weekend. I have a Kenwood with wireless CarPlay from my ‘15 Ram. Really liked the wire free in that.
