AlfaOBD Known Changes 5th Gen
Just for one example, try to use your adapter to connect AlfaOBD to the climate control module, and let us know the result.
Nada.
Truck throws an ABW popup and goes away.
I didn't think Alfa could even connect to those modules, my Micropod can connect to them though.
What would it allow me to do or see if it did work? stored codes?
It's not possible to use my Bluedriver with Alfa right?
I have reset airbag and ABS codes with one before.
Alfa let's you connect to them just fine if you have the right OBD adapter and not a cheap one. The MX and MX compatible ones work.
Interesting.
I guess I was wrong then and I do have some subpar device.
I do know I don't have any speed problems and when I run the tested with torquepro it says the device is a proper one as it has a lot of warnings about bad clones.
Hello
I am new here and I have did some research for my problem, but seems I did not find a answer for it.
I have ram rebel 2022 and I am trying to like this guy in the youtube but it seems does not work. is there something I need to do or like is there specific version for that mine did not work.
I use the OBDLink EX because the USB cable makes me feel cool.
Hello
I’ve done it, but with jscan so it should work. Make sure you go into your trucks radio settings and enable the DRLs in there too. Otherwise you’ll never see them
Hi all,
Read thru the thread, but just to understand the general consensus, you can’t add off road and performance pages to a Uconnect 5 truck??
I have a 22 ram Big Horn with 12” screen.
Hi all,
Only if you remove your telematics box.
If you add them you only get them on your EVIC, not radio.
Did the Turn Signal DRL make the top and bottom amber? Kinda looks like the top is still white.
No it doesnt. The original white lights are the signature lighting. They are always on regardless of the DRL setting. Here's @5thgen.ram 's truck. It's easier to see in this picture.
