alorentz
- Jan 27, 2022
I hope someone has experience with AlfaODB, or other application to adjust tire size, and knows what they are doing...because I'm guessing!!
I have 2022 RAM 1500 Crew Cab, 5.7L, 2300 miles. Stock were Alenza Dueler 31in tires. I switched out for Wildpeak AT3W 275/60/20, which are 33.1 in. I noticed my AVG MPG was pretty low, at around 10.9 MPG, and the MPH was not correct as compared to GPS app. Gas mileage is terrible, and speedo is wrong. I read that I need to change the config so the new tire size is accurate, which affects MPG and speedo, on other stats. The dealer doesn't do this, so I purchased an SGW bypass, and downloaded the AlfaODB app on an Android. Hooked it all up, and am able to change configurations in the vehicle. Stock tire circumference of the 31in was 2462mm. The new 33.1in tire is 2642mm (approx). I adjusted the Tire Program Size in the app, and set the config to 2642, and then tested MPH on the highway with the GPS app. It appears the truck was running about 3 MPH higher than the GPS app, meaning speedo showing faster than actual. So, I dropped the tire circumference in AlfaODB to 2585, and then the truck ran about 1 MPH under GPS. So, I changed circumference to 2595. Now the truck MPH and GPS MPH are running the same, so at 2595 truck speedo is accurate.
Here's the question, am I supposed to put in the exact circumference of the tires, which is 2642, which makes the truck speedo/MPH faster by about 2-3 MPH than the vehicle is actually going. OR, am I supposed to adjust tire circumference in the config until the speeds match in the truck and GPS, which is about 2595...which is smaller than the actual 33.1 in tire? I'm lost.
