Jordan3206
- Apr 21, 2019
Okkkkkkkkkkkkk, because I didn't find all the info i needed to do this I'm sharing my experience as I just completed this last night. Yes it works. Factory ride has been restored. Only once concern.
1.Drop the truck to aero to conserve as much nitrogen as possible and disconnect the battery. Electronic PS systems are sensitive.
2. You only need to drop the UCA BJ, sway bar at the frame, tie rod end, and all bolts attached to the strut. With these removed the strut easily comes out. The air line will leak when you remove it. Don't use a pickle fork. The tie rod fell out on mine and the UCA popped out with a few 3lb hammer blows to the spindle.
3. I Trimmed 1/4" off my strut studs. I believe this is needed to make sure the strut extensions sit flush and don't impact the strut hoop causing noise.
4. As far as the UCA. With the strut removed i reinstalled the UCA to the spindle and the UCA is going to smash the air ride sensor and the air strut before it binds at the BJ. The MOPAR UCA is not needed. However, know that if you go full extension you are probably going to damage that sensor depending on how great the impact. This could potentially be solved with a relocation bracket for the sensor or maybe limiting straps.
Alignment in a few days. Will update after.
