You probably need to get out for about 15 mins and open the hemi a bit and you'll notice the difference.Just finished my install. A few observations. If your Advance Auto doesn't have the parts, O'Reilly can find them using the same numbers. I had to go to two O'Reilly stores.
Pretty sure you could not pay me to do it again. Reason? That tension hose clamp. If I were doing it again, I would destroy it and use a third clamp of the other type. I did so poorly working with it I fear I will have a leak when I open the valve in Winter.
Finally, I am not certain I am actually getting any benefit. If so, it's no more than 3/4 degrees. That's on a limited drive though. I have to take a longer drive this afternoon, so I will test again.
