Can you guys with 5.7s post pics of your installs?
Also, is there any downside to zero flow? Would a three way ball valve on the pressure side, and a tee on return line be safer?
so what are your temps since the re flashUPDATE: Just picked up truck from dealer and they said in fact it's the heater blend door which is operated by a servo motor, they reflashed the head unit which recalibrated the climate controls and resets end points which would eliminate tearing into dash and AC seems great !!! FYI the 1500 series trucks do in fact use 1234yf Freon and 2500 series up still maintains 134a
Literally waiting for FCA to fix this to pull the trigger around Christmas. If this is still and issue for 2021 models then I'll either wait for 2022 or get a Ford. I would have pulled the trigger sooner had this issue never existed.I have spread the word in private message to RamCares to please share this info to the engineers that it is an obvious blend door issue. They agreed that they would. I have also emailed TFLtruck and got a reply from Andre Smirnov that they will look into AC temps as they haven't experienced warm weather yet. I also told him results of shutting down coolant flow. I am sure informing these 2 sources should "turn up the heat" on the engineers for a resolution.![]()
Just installed my automatic solenoid, just flip a switch under the steering wheel and the heater core is shutoff. View attachment 58471
While I admire your ingenuity I think this is overkill. I guess it's nice to have a switch to flip but, how often would someone really need this ability on what really is a twice a year or so switch. IMO a manual valve to shut off flow in late spring/early summer and back on in early fall is foolproof & the easiest, most reliable option.Especially with those (like you & me) being in the northeast as I'd also be worried about the long term exposure to road salt, water, etc of the unit & wiring over time leading to failure.
I've been thinking of going this route down here in Georgia in the beginning and end of air conditioning season it is hot during the day and and at 2am in the morning when I get off work there can be chill outside.While I admire your ingenuity I think this is overkill. I guess it's nice to have a switch to flip but, how often would someone really need this ability on what really is a twice a year or so switch. IMO a manual valve to shut off flow in late spring/early summer and back on in early fall is foolproof & the easiest, most reliable option.Especially with those (like you & me) being in the northeast as I'd also be worried about the long term exposure to road salt, water, etc of the unit & wiring over time leading to failure.
If I lived in that type of climate range and saw a new gen Ram with the hood open and on the side of the road, I'd know exactly what was going on, lolI agree with dts828, not going to be a twice a year adjustment for some of us. Out in CA, in the SF bay area our hot and not days can very quickly come and go spring through fall. Last week we had three days of upper 90s then it dropped down to barely 70. And in the same day you can have 90s here in the valley, drive over to the beach (or SF) and it's a foggy 55.
That said I'm loath to start cutting on my truck which I've only had a month. I would much prefer for FCA to figure this out and provide us a fix.
If wired correctly it should never give you a problem, I’m pretty experienced with these types of things so I am confident it won’t give me any problems. If something were to happen the valve is normally open so everything would flow as intended by ram. As for only needing to change the valve twice a year, I’ve turned it on and off probably a dozen times since I’ve installed it, for example today it’s 50 degrees so I have the switch off but just a week ago it was in the 90’s for three consecutive days. And as for the manual valves, I’ve seen several people on here say theirs is starting to leak. I don’t know about you but I know that a coolant leak is no joke especially on a long road trip. So I appreciate the concern but I will take my setup over a manual valve any day of the week.While I admire your ingenuity I think this is overkill. I guess it's nice to have a switch to flip but, how often would someone really need this ability on what really is a twice a year or so switch. IMO a manual valve to shut off flow in late spring/early summer and back on in early fall is foolproof & the easiest, most reliable option.Especially with those (like you & me) being in the northeast as I'd also be worried about the long term exposure to road salt, water, etc of the unit & wiring over time leading to failure.
www.electricsolenoidvalves.com
You do understand the clamp is designed as a temporary solution to stop coolant leakage when the system is being worked on? Using them long term could crush and degrade your hose. The valves are designed to be permanent. Every one makes their own risk assessment, and you are making yours. Personally I carry a spare, (but even better brass valve) as a backup. I've had my Ram in for service three times so far with the valve in place, and no one even noticed. I'm an old car/truck guy, I still check the oil when I fuel up, and look over the engine to see if anything is out of place. If the valve fails, it will likely be a small leak or seap. If your hose fails, it will likely be a "burst".I agree about the manual valves and the possibility of leaks/failures - not only that but the possibility of warranty issues if they see it when in for repairs ( one worst case scenario would be if you broke down and had to have it towed to dealer with no time to remove the valve and put it back to stock)....which is why I went the Harbor Freight clamp route.
I'm surprised you need to use it so much in the northeast climate....I install the clamp in mid/late May in NJ and then remove in late Sept or early October. Plus, I can always physically reduce pressure on the clamp while it's installed if I needed to on an unexpected cold day but that has not been necessary at all. Also, no real issue with window fogging/needing heat to clear it up. From reading here, everyone has different needs depending on their climate but one thing that is clear is the clamp is the simplest "do no harm" option for the issue and the easiest to "delete" if required.
Stay cool,
