James Cole
- Oct 14, 2018
Just installed the brass valve that @Jhill recommended, definitely quality piece, just wondering if its up to the temperature task, but no leaks whatsoever.
As for the A/C performance right now is on par with other vehicles, very satisfactory results, it's working as it should be from the factory now.
Did some tests when I was purging the system of air after the the valve install, closed and opened the valve while the engine was running and radiator cap off, there is no added pressure on the system when closing the valve.
Very happy now, thanks @KcRay !
