KcRay
Today I was able to get 36-38 degrees blowing out of both the drivers side and the passenger side ac vents. Previously I was getting 44 out of the passenger side and 50-52 out of the driver side. I installed a water shut off valve in the heater hose going from water pump to the heater core. It's the outbound side of the pump says "out"right on the hose. This stops any hot water from getting into the air conditioning system at all. You will have no heat when the valve is closed, for the heater you will have no way to control the air conditioning temperature it will be as cold as it can be. This was only a test for me if you decide to do this it will be at your own risk. In essence this proves there's definitely a blend door issue inside the dash letting hot water into the HVAC system when we are telling it not to
