Adding valves to bypass the stock exhaust
Groffer
Upstate NY
I purchased a 2021 RAM 1500 Laramie in 2023 and I'm looking to switch to a different type of exhaust for a more aggressive sound. I have a few common concerns that most people do:
  • Drone
  • Waking up the neighbors (I live in an apartment complex)
I don't dislike the stock exhaust, it has been nice for long drives to keep the noise in the cab down, but it would be nice to have the extra bite when I want it.
I looked into the exhaust dump valves, and I wasn't happy with the way they sounded, so I had the idea of adding valves to bypass the stock exhaust and go through a Magnaflow/Flowmaster setup (see the picture I attached)
I would have a shop weld it together for me and I could do the wiring myself with an Arduino/Raspberry pie so I could add switches in the cab. One of my concerns is both valves get stuck closed and suffocate the engine, so I could add a flow meter or sensors to verify that the valve opened correctly and I don't have ridiculous back pressure.
What does everyone think? Is this too complicated or do we think that it could work? I know the drawing would cause a reduction in flow so I would probably be losing engine power if I went this route.
kapinallinen2
5thGenRams Supporter
Southern Maryland.
  • Drone
Providing there is enough room for the flow-master, why not just use one valve for it and leave the stock open.
theblet
I doubt there will be enough room for two mufflers, especially with the huge stock one in place.
What about a small tame muffler for traveling and a straight pipe bypass?
Groffer
Upstate NY
I think I'd like to keep the stock muffler as an option if I could fit it under there. I might be able to move the stock muffler closer to the front and squeeze a parallel 3" pipe by it so I can offset the Flowmaster toward the back axle. I don't have the front resonator like the 2019 and 2020s do so that shouldn't be an issue.
My biggest concern is putting too much back pressure on the engine
Groffer
Upstate NY
I like that idea, it seems more simple than using two. I wonder if this would create a weird case where the frequencies combine and amplify when they hit a certain Hz if the flow is still going through both
kapinallinen2
Southern Maryland.
Well, "combine and amplify" is a bonus in my line of work, you can always add the second valve later on if needed.
Groffer
Upstate NY
Lol fair enough, I was more getting at the drone inside the cab. I was thinking about the 40 Series Delta Flow and taking off the rear resonators, especially since I'd still have the stock option on there.
kapinallinen2
Southern Maryland.
Pretty sure no one here has done that before, keep us posted on how it turns out.
