Adding Rear Console USBs
I think the part number you're looking for is 68438655AA. (WIRING, Console : [X8S], [JKV], [JJN], [RS4], [RFX], [JPZ] AND/OR [CAH])
This has all the options available for the center console.
Will this work with the CD player option as well?
Yes, the CD player connector is a 16 pin black connector with a white back. 68438655AA has all the options so the connector is there. Still need programming to make it work in the vehicle as well as CD player only works with Uconnect 4 and not UC5.
Thank you for all your help. Just to clarify, I have the factory cd player. I do not have the rear factory usb ports. If i find a donor console with factory rear usb I will need programming to make it work?
For the USB ports, no programming is needed, just needs power/ground and data connection for USB hubs to work. If you already have a CD player then you have the programming in the BCM for the CD player to work. You just need the console harness to have the same connectors you already have plus extra connections on the harness for the rear USB hub. I recommend getting the console harness with all features, any you don't use will just hang inside the console. Out of sight out of mind. 😁
Thanks for all your help. I ended up finding a complete console for $125 cash with the rear USB ports and no invertor plugs from a local recycler in great condition. I felt like I was stealing it from them!!! Installed in 15 min. Took me longer to clean the console. Everything works and the kids have power now. Now maybe Ill tackle adding the invertor if I can figure out the wiring since the console is prewired for the two plug ports.
Got my USB hub and 115v plug install finished on the '25 Rebel today. Well sort of. Here's the story.
Mopar Parts:
Wanted to use this aftermarket media hub bezel. Didn't work out. Didn't evaluate the existing one well enough. It only consisted of one large storage bin. I didn't have blanks or smaller storage tray.
I was able to make the old one work by creating holes with a Dremel tool. Recessed inside the storage bin. A little difficult to open the power outlet, so I just left a usb-c plug in it. Just take the cable in and out.
Console came out easy enough, but running the wiring harness had some tight spots, and my hands took a beating.
Going to see how the modified bezel works out before I reach out to the dealer where I ordered the parts for the correct one. Might be fine. Might not. We'll see.
Got the console reinstalled and tested all ports. They all worked, so I'll be done until I decide on the bezel.
Mopar Parts:
Had to order a complete end cap to finish the project. Might have been cheaper just to buy another truck with the media hub already installed. :sneaky:
7va431x7aa
Anyway to just wire up 68572629AA with the existing wires that run back there? Only looking for usb charging. Wouod like to keep it simple.
Does anyone make a pigtail connector to connect the usb hub?
Don't know for sure personally, but I think I read something about one in an earlier thread. Check out the thread I linked earlier. That's a good thread with varying processes.
Apologies for 'resurrecting' an older thread. I was searching for part numbers to complete this, and thanks to this thread I've gotten most of them. I'm struggling to locate the proper OEM part number for the "center console end cap" - Browsing the mopar parts site, I've found a number of part numbers named properly, but there's never a description for what holes are present for the usb/110v/etc button install, or what the panel material looks like (though I'm not entirely certain there's an option other than the plain black plastic). I suppose if I can't find something, the easier thing to do would be buy a whole center console from ebay or a local auto scrap yard or something...
This was what I put on my '25 Rebel.
What's your model year and trim? There are differences.
I know this is an old post but I just upgraded my center console to the limited but I have the end cap from my Laramie with the USB Plugs and the plug, also has the heated and vented seat options for further upgrades if u please will list it right let me know if interested
