Interesting. I don't think I plan on doing it anytime soon as I have some other projects that I've prioritized. I like knowing that the idea is there. I'm not sure if anyone else is interested in doing it, I found some parts based on what you said. Not sure if these are the right ones, but most are identified as "dual zone", so I feel they are pretty spot-on:
AC and Heater Case (HVAC box?) - 68396071ac
Temperature Sensor (x4) - 68396045AA
Motor - 68396057ac
Sun Sensor - 68230114ab
cabin Temp Sensor - 55111178AC
Some I found that you didn't mention. Would the harness be different? The Air Distributor might be part of what you consider the HVAC Box
Air Distributer - 68396073AA
Harness - 68396054AA
Seems like the whole thing would be around $400. What would the new Sun and Cabin Sensor do?
Parts needed:
(1) HVAC case- 68396071AC
(4) duct temp sensors- 68396055AA
(1) blend door actuator- 68396059AA
(1) sun sensor- 68230114AB
(1) cabin temp sensor- 55111178AC
(1) harness- 68396954AA
The harness is MUCH cheaper than it was last year (cheaper than I can build it for now), that’s why I built add-on harnesses for the guys that did this swap.
The cabin temp sensor, and duct temp sensors are needed for auto temp control to work properly. The new sun sensor is needed for ATC, also, because it has two extra circuits that takes into account sun load heat coming through the windshield.
There is no need to get the specific dual climate HVAC distribution box because it is structurally the same as the one you have, it just has the holes provided for the four duct temp sensors. You can drill those holes yourself into your existing distribution box.
So, you’re looking at about $280 (assuming you already have AlfaOBD), plus whatever you’ll get charged to evac/recover AC system, and about a gallon of coolant.
