768mph
- Jun 24, 2018
im interested in this also did a search with not muchThere are multiple threads about A.C. concerns..take a moment and use the search function at the top right of the page and you'll find a lot of information.
Here are two that I found pretty quickly.
https://5thgenrams.com/community/threads/a-c-performance.605
https://5thgenrams.com/community/threads/ac-engaging-on-its-own.1875/#post-26839
That first link offered up by @202snowman includes an FCA chart showing the specification for AC vent temps depending on outside air temp, at post #6. According to that chart your system is performing very close to spec for temps above 80 degrees. I’m not trying to tell you what you should be happy/unhappy about, but if the techs get the same measurements you should be prepared for that answer.I did search, it didn’t result in any hits. “AC Temps” “A/C” “AC” “Air conditioning” were either too short or not found. Try adjusting the search engine.
Same here, hence why I posted.
Thanks.
Just picked my new Limited up this week. Hot outside /hot inside. Wife won’t ride in hot truck. Had to drive with windows down /back glass open in a 67K truck. This truck won’t last long in my driveway at this rate. #shouldhsvegotanotherf150It was about 83° today and put my AC on max (not recirculating) and LO. Results were between 47-55°
Not good. Going to take it in. What about everyone else?
You should have ! They are trouble free, check the forums my friend!#shouldhsvegotanotherf150
