MF2020
87 for me.  Used it in my 2011 5.7 and using in my 2020 5.7 with etorque.  I notice no difference between 89 & 87 in either power or milage, with or without a trailer seems to make no difference either.
			Deoends the reason the PCM was pulling timing. It is written into the tune to pull timing during WOT shifts to be easier on transmission. So if you are reading log files and see timing being pulled at top of RPM right before shifts, that's why. There are a wide variety of reasons for timing to be pulled. Need to log more than just timing to reallying see what is going on. What is the LTFT and STFT? Oil temp, water temp, IAT reading..............That would theoretically be true; however, at least one member ran a test at all grades and observed the computer was still pulling timing (slightly) even on 93. So…maybe the HEMI tune leaves some room for additional performance.
Understood, and valid points. I can’t speak for the member that shared this, but if all else were equal…Deoends the reason the PCM was pulling timing. It is written into the tune to pull timing during WOT shifts to be easier on transmission. So if you are reading log files and see timing being pulled at top of RPM right before shifts, that's why. There are a wide variety of reasons for timing to be pulled. Need to log more than just timing to reallying see what is going on. What is the LTFT and STFT? Oil temp, water temp, IAT reading..............
Will create more deposits in cylinder, doesn't offer any advantage over 89 that the truck is tuned for.
SaMe reasom you will detonate on 87 but not 89Why would 93 leave more deposits vs 89 or 87?
That's an octane difference, and that will not cause deposits.SaMe reasom you will detonate on 87 but not 89
What did I say that is not true? Since the ECU compensates, as it's designed to do, timing for octane I get no ignition-related issues (knock/ping). I easily, and regularly achieve over 21MPG with my cruise set at 72, and over 20 set at 75. (BTW-this still blows my mind and makes me really happy). If I fill with midgrade fuel (89), I pay at minimum 10% more....there is no viable way to economically justify that as my mileage absolutely will not increase by 2mpg. I drive lots of highway, so any torque loss means relatively little unless I'm towing or hauling heavy. If that were the case then I might use 89, but that still would not compute to make economic sense.Not true.
87 only allows for X ignition advance which is what creates low speed torque and upper room horse power.
Lowering the ignition advance decreases torque output requiring more throttle, more rpm and more fuel to accelerate to a specific speed.
We may only be talking 20-30 lbs ft of torque but over the course of a tank of fuel you'll consume more.
My previous truck averaged about 1.5 mpg less on the highway alone and I've seen the timing impacts on Dyno in my car
That fuel economy is unchanged, that's not accurate.What did I say that is not true? Since the ECU compensates, as it's designed to do, timing for octane I get no ignition-related issues (knock/ping). I easily, and regularly achieve over 21MPG with my cruise set at 72, and over 20 set at 75. (BTW-this still blows my mind and makes me really happy). If I fill with midgrade fuel (89), I pay at minimum 10% more....there is no viable way to economically justify that as my mileage absolutely will not increase by 2mpg. I drive lots of highway, so any torque loss means relatively little unless I'm towing or hauling heavy. If that were the case then I might use 89, but that still would not compute to make economic sense.
Exactly, I don't see how theres an argument that 87 reduces performanceI saw a video on youtube where a guy logged (hp tuners) his hemi with different gas. The point here is that the computer pulled much more timing on 87, than it did on 89. So while the "wide variety of reasons" may be true, those reasons would still be there when running on 87 vs 89 when that is the only difference between tests. What is being claimed is that these hemis so obviously run far better on 89+
What you're saying doesn't make sense. The formula for horsepower is Torque x RPM / 5252. If you have a reduced torque output at given RPM you have reduced performance. Plus, it's not just the top end number you should be looking at, it's the area under the curve (as in gains made or lost along the RPM range).That fuel economy is unchanged, that's not accurate.
Ignition advance = torque, period. Reduce the advance, reduce the torque output at a given rpm and you increase throttle input to obtain that same performance or rate of acceleration, that results in increased fuel consumption.
And yet....so what??? I keep more money and my truck runs great. Period. I've driven an overall average of just over 30K miles per year since I started my career 33 year ago. My wallet math is far more significant, to me, in this case than your theoretical math. And I've tried 89 for several tanks in a row...my fuel economy difference is no where near even 1 mpg overall. 87 for me.That fuel economy is unchanged, that's not accurate.
This. Only difference is in the wallet. Manual clearly states 87 is fine. I drive 90% highway and regularly attain 20+mpg with no knock, no ping, no nuthin. Truck runs great.
You are splitting the finest of semantic hairs....to what end I really don't know. I was simply stating my experience and preference as the OP requested.That's fine but say that instead of blanetley that it doesn't affect performance or fuel economy. As for mpg, do what you want, I can see an easy 1.5-2 mpg difference at highway speeds driving from Dallas to Houston as have many others
